Single continuous solid infill
Sheflya
(@sheflya)
Is there a way to force the extruder to do the single continuous solid infill rather than multiple infill types?
For example:
Infill
This is a 100% infill layer that has 3 different infill types (red, purple and dark red)
I want to force the extruder to do it in a single one as there is no real benefit in separating it in 3 different types. Single one is faster and more solid.
Postato : 17/09/2023 7:51 pm
RE: Single continuous solid infill
Have you tried lots of top layers instead of infill?
Postato : 18/09/2023 7:24 am
Sheflya
(@sheflya)
That doesn't help
Postato : 18/09/2023 4:47 pm
Can you please attach a zipped copy of your project file from Prusa Slicer?
Postato : 19/09/2023 5:14 am
Sheflya
(@sheflya)
Here's the file.
But I don't really have a problem with this particular part, it prints just fine, I'm talking in general.
For example consider this part... Layer before:
Layer after:
In this case the blue infil (bridging. I'm not really sure why this is bridging infill) does not have enough support form layers below and that part of the layer will print badly. The part won't fail because of it but the quality of the infill will not be as good as if it was one continuous infill of the entire layer
Questo post è stato modificato 3 years fa 2 tempo da Sheflya
Postato : 19/09/2023 3:18 pm
No file attached.  It has to be zipped or the forum will silently just not attach it.  With the edit window also being short on the forum its 'best practice' to check your post afterwards to make sure it actually did it.
Postato : 19/09/2023 9:34 pm
Sheflya
(@sheflya)
I'm not sure why it doesn't work. I tried zip, 7z, rar and nothing.
Here's the download link: LINK
Postato : 20/09/2023 7:46 pm
