Significantly worse results on PrusaSlicer
Hello
I have a problem with the quality of printing using PrusaSlicer. As long as the walls are smooth, everything looks beautiful. However, when some patterns or embossments appear, the quality of the print drops, unevenness, breaks and some fluff appear. Does not matter if it is PLA, PETG or ABS - the result is similar. I was tearing my hair out, I performed all possible calibrations, and disassembled the printer to the last screw. Until finally yesterday I did an experiment. I used a different slicer. And the problem disappeared. I used the same STL model, the same printer obviously, the same filament, the same printing speeds and accelerations, the same temperatures, cooling... Everything that could be set the same, was set the same. As you can see in the pictures - the difference is significant. What could be the reason? Some other setting in PrusaSlicer?
Printer: Ender 3 S1 PRO, Filamnet of presented prints: PETG Fiberlogy, Bed 70 deg C, Nozzle 240 deg C
