					                		Restoring Gcode back to default from BGcode after updating. - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/</link>
                <lastBuildDate>Wed, 15 Apr 2026 01:32:10 +0000</lastBuildDate>
                        <title>RE: Restoring Gcode back to default from BGcode after updating.</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761321</link>
                        <pubDate>Sun, 17 Aug 2025 17:31:12 +0000</pubDate>
                        <description><![CDATA[thanksi hope i&#039;m back now on the right trackgr geert]]></description>
                        <content:encoded><![CDATA[<p>thanks</p><p>i hope i'm back now on the right track</p><p>gr geert</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>geert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761321</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761319</link>
                        <pubDate>Sun, 17 Aug 2025 17:04:21 +0000</pubDate>
                        <description><![CDATA[Once you made the change did you save the updated profile as a new one ?  You cant make changes to the default ones and save them.  They must be saved with a different name.  Then you need t...]]></description>
                        <content:encoded><![CDATA[<p>Once you made the change did you save the updated profile as a new one ?  You cant make changes to the default ones and save them.  They must be saved with a different name.  Then you need to always slice with your modified profile.</p><p>A simpler way if you don't want to save copies of all the profiles is to go into Configuration&gt;Preferences (Cntrl+P), navigate to the Other tab and there you should find an option called " Use Binary gcode when the printer supports it".  Make sure that is Unticked.   Prusa added it due to pressure/feedback on the PS github.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761319</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761313</link>
                        <pubDate>Sun, 17 Aug 2025 16:06:22 +0000</pubDate>
                        <description><![CDATA[strange, it worked only once now i get the bgcode againgr geert]]></description>
                        <content:encoded><![CDATA[<p>strange, it worked only once now i get the bgcode again</p><p>gr geert</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761313</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761311</link>
                        <pubDate>Sun, 17 Aug 2025 14:09:35 +0000</pubDate>
                        <description><![CDATA[thanks i will try thisgeert]]></description>
                        <content:encoded><![CDATA[<p>thanks i will try this</p><p>geert</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761311</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761309</link>
                        <pubDate>Sun, 17 Aug 2025 13:58:44 +0000</pubDate>
                        <description><![CDATA[de select the &#039;Supports Binary Gcode&#039; optionIn the Printers  General, Sub menu(need to be in Expert Mode!)]]></description>
                        <content:encoded><![CDATA[<p>de select the '<strong>Supports Binary Gcode</strong>' option</p><p>In the <strong>Printers  General,</strong> Sub menu</p><p>(need to be in Expert Mode!)  </p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/f2794576-g-code.jpg"><img class="alignnone size-medium wp-image-179559" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/f2794576-g-code-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761309</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761308</link>
                        <pubDate>Sun, 17 Aug 2025 13:48:19 +0000</pubDate>
                        <description><![CDATA[hi ,can you explain how to change the bg code back to g code?after a update to 2.9.2 nothing works anymore, not a download, no drawing i makethis a disasterthanksgeert]]></description>
                        <content:encoded><![CDATA[<p>hi ,</p><p>can you explain how to change the bg code back to g code?</p><p>after a update to 2.9.2 nothing works anymore, not a download, no drawing i make</p><p>this a disaster</p><p>thanks</p><p>geert</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-761308</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-701811</link>
                        <pubDate>Wed, 28 Feb 2024 22:50:03 +0000</pubDate>
                        <description><![CDATA[This is a question best asked on the Prusa Slicer Git hub!Joan]]></description>
                        <content:encoded><![CDATA[<p>This is a question best asked on the Prusa Slicer Git hub!<br /><br />Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-701811</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-701710</link>
                        <pubDate>Wed, 28 Feb 2024 10:10:51 +0000</pubDate>
                        <description><![CDATA[Right … Question to the development team: Will this bug be corrected in the next future?]]></description>
                        <content:encoded><![CDATA[<p>Right … Question to the development team: Will this bug be corrected in the next future?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>HFM</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-701710</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-691574</link>
                        <pubDate>Thu, 28 Dec 2023 19:06:00 +0000</pubDate>
                        <description><![CDATA[Posted by: @lukas-15 Yes, but it&#039;s problem, because via Prusa Link it&#039;s not uploading bgcode :( It&#039;s reported as bug. Posted by: @charlie-essers The latest firmware will enable binary gcode ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="545109" data-postid="691429" data-mention="lukas-15"><div class="wpforo-post-quote-author"><strong> Posted by: @lukas-15 </strong></div><p>Yes, but it's problem, because via Prusa Link it's not uploading bgcode :( It's reported as bug.</p><blockquote data-userid="263602" data-postid="689360" data-mention="charlie-essers"><div class="wpforo-post-quote-author"><strong> Posted by: @charlie-essers </strong></div><p>The latest firmware will enable binary gcode on your Mini: https://help.prusa3d.com/downloads</p></blockquote></blockquote><p>Unless there's a different Mini specific bug, AFAIK, it's the clicking through file explorer option that is kinda bugged only because it doesn't show bgcode filetypes by default. But you can just change the extension type to "All Files (*.*)" and you'll be able to select bgcode to upload, or just simply drag your file(s) onto the browser window when on the Storage page to upload.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>BaconFase</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-691574</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-691429</link>
                        <pubDate>Wed, 27 Dec 2023 18:13:39 +0000</pubDate>
                        <description><![CDATA[Yes, but it&#039;s problem, because via Prusa Link it&#039;s not uploading bgcode :( It&#039;s reported as bug. Posted by: @charlie-essers The latest firmware will enable binary gcode on your Mini:]]></description>
                        <content:encoded><![CDATA[<p>Yes, but it's problem, because via Prusa Link it's not uploading bgcode :( It's reported as bug.</p><blockquote data-userid="263602" data-postid="689360" data-mention="charlie-essers"><div class="wpforo-post-quote-author"><strong> Posted by: @charlie-essers </strong></div><p>The latest firmware will enable binary gcode on your Mini: https://help.prusa3d.com/downloads</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Lukas</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/setting-gcode-back-to-default-from-bgcode-after-updating/#post-691429</guid>
