Set the hotent to wait until bed is preheated
Roman Sato
(@roman-sato)
Hi guys,
On my 3D printer, the hotend heats much faster than the bed does. Due to this, the hotend is waiting for the bed to heat and the filament is ageing at high temperature.
Today I do modification of the gcode as shown bellow for each program. Is there any possibility to include this in prusa slicer as an settings.
Unmodified gcode:
;Start GCode begin
M140 S55 ;Start Warming Bed
M104 S160 ;Preheat Nozzle
G28 ; home all axes
G90 ;absolute positioning
G1 X-10 Y-10 F3000
G1 Z0 F1800
G1 Z5 F5000 ; lift nozzle
M190 S55 ;Wait For Bed Temperature
M109 S200 ;Wait for Hotend Temperature
G92 E0
Modified gcode:
;Start GCode begin
G28 ; home all axes
G1 X-10 Y-10 F3000
G1 Z0 F1800
M104 S160 ;Preheat Nozzle moved to new position
G92 E0
BR
Roman
Posted : 11/07/2021 6:47 pm
RE: Set the hotent to wait until bed is preheated
You can insert the modified lines into the start gcode in PrusaSlicer. See Printer Settings->Custom G-code->Start G-code.
Posted : 12/07/2021 4:37 am
towlerg
(@towlerg)
FWIW I allow both nozzle and bed to heat up at their max rate but set the nozzle to 90% unlill bed is up to required temp. I have preheat in Octopint the same.
Posted : 12/07/2021 11:29 am
Roman Sato
(@roman-sato)
Nice coments
I agree I'm new in this never tried to work on g-code 🙂 or optimize the printer flow. The question is not about what to optimize but more about, how to set this in Prusa slicer to add this on every g-code and not to modify each g-code.
BR
Roman
Posted : 17/07/2021 4:14 pm
davorin
(@davorin)
What I do is heat up the bed first as it takes much longer.....but to a lower temperature...then when it is reached, heat up the nozzle and continue to heat up the bed to the target temperature....
The example Start G-Code is also available on the Prusa slicer docs:
M190 S{first_layer_bed_temperature[0] - 5} ; Heat up bed 5° lower and wait
M140 S[first_layer_bed_temperature] ; Continue heating to full temperatue and don't wait
M109 S[first_layer_temperature] ; Heat up the nozzle while bed is heating up
Just add this into your printer settings Custom G-Code -> Start G-Code section.
Ender-5 Plus
with Micro Swiss Direct Drive, BTT SKR v1.3 and TMC2208<br>Ender-3 with Micro Swiss Direct Drive, E3 mini with TMC2208<br>Qidi i-Mate S
Posted : 22/07/2021 8:28 am
