Set min height on var. layer height?
TeachThePrints
(@teachtheprints)
Is it possible to set a minimum layer height, when using the variable layer height setting?
My Mini sometimes runs into an issue, where it clogs during the smallest layer height, which I assume is 0.05mm. So it'd like to increase that slightly.
Is this in any way possible?
Best Answer by Neophyl:
Yes.  It uses the layer heights from Printer Settings>Extruder>Layer Height Limits.  Those are Yellow settings so you need to be in Advanced or Expert mode to see them.
Prusa Mini FW6.2.4
Posted : 15/11/2022 1:01 pm
RE: Set min height on var. layer height?
Posted : 15/11/2022 1:04 pm
TeachThePrints
(@teachtheprints)
Perfect. Such a straightforward fix
Prusa Mini FW6.2.4
Posted : 15/11/2022 1:37 pm
