					                		Scaling of certain areas only - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/</link>
                <lastBuildDate>Mon, 11 May 2026 00:32:16 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-733151</link>
                        <pubDate>Sun, 19 Jan 2025 15:12:03 +0000</pubDate>
                        <description><![CDATA[Kind of.  I lengthened a part in Prusaslicer by cutting it into 3 sections, scaling the center section, then rejoining the sections.  I had to eyeball it a little, but was able to line them ...]]></description>
                        <content:encoded><![CDATA[<p>Kind of.  I lengthened a part in Prusaslicer by cutting it into 3 sections, scaling the center section, then rejoining the sections.  I had to eyeball it a little, but was able to line them up well within the resolution of any printed job.  I could have used Fusion CAD but this was quicker.</p>
<blockquote data-userid="17789" data-postid="375556" data-mention="mc-2">
<div class="wpforo-post-quote-author"><strong> Posted by: @mc-2 </strong></div>
<p><span class="style-scope yt-formatted-string" dir="auto"> Is there a way to scale certain areas only? If I scale a model on the z-axis - the whole z-axis is scaled. </span> <span class="style-scope yt-formatted-string" dir="auto">I would like scale a certain area - i.e. the middle section of the model an keep the original dimensions of the top and lower secions.</span></p>
<p>Is this possible on the current PrusaSlicer or any other slicer out there?</p>
<p>Cheers</p>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>LarGriff</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-733151</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-732970</link>
                        <pubDate>Fri, 17 Jan 2025 20:46:06 +0000</pubDate>
                        <description><![CDATA[Since you can select a range of layers, it makes sense to me that all of the operators could be constrained to the selected layers.Yes, trivially easy to implement; of course the part would ...]]></description>
                        <content:encoded><![CDATA[<blockquote><p>Since you can select a range of layers, it makes sense to me that all of the operators could be constrained to the selected layers.</p></blockquote><p>Yes, trivially easy to implement; of course the part would then fall apart at those layers but that, presumably, is irrelevant.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-732970</guid>
                        <title>RE: Scaling of certain areas only</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-732959</link>
                        <pubDate>Fri, 17 Jan 2025 19:37:53 +0000</pubDate>
                        <description><![CDATA[Posted by: @neophyl That is a function of cad software and not a slicer. If you want to do that sort of stuff then you should really learn some form of cad program. You could spend lots of t...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="90840" data-postid="375574" data-mention="neophyl"><div class="wpforo-post-quote-author"><strong> Posted by: @neophyl </strong></div><p>That is a function of cad software and not a slicer. If you want to do that sort of stuff then you should really learn <em>some </em>form of cad program. <br />You could spend lots of time using the cut and export function to generate 3 separate stl files, which you could then theoretically import back in as parts and scale a part. However lining everything up and actually doing it would probably take as much time as learning how to do it in cad.  The actual operation in cad would probably only take minutes once you know how to do it. </p></blockquote><p>Only 2 minutes to do after who knows how many days and weeks of learning how to use the CAD program.</p><p>Since you can select a range of layers, it makes sense to me that all of the operators could be constrained to the selected layers.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>ChiTownGuy</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-732959</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-375574</link>
                        <pubDate>Thu, 18 Feb 2021 15:54:00 +0000</pubDate>
                        <description><![CDATA[That is a function of cad software and not a slicer. If you want to do that sort of stuff then you should really learn some form of cad program. You could spend lots of time using the cut an...]]></description>
                        <content:encoded><![CDATA[<p>That is a function of cad software and not a slicer. If you want to do that sort of stuff then you should really learn <em>some </em>form of cad program. <br />You could spend lots of time using the cut and export function to generate 3 separate stl files, which you could then theoretically import back in as parts and scale a part. However lining everything up and actually doing it would probably take as much time as learning how to do it in cad.  The actual operation in cad would probably only take minutes once you know how to do it. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-375574</guid>
                        <title>Scaling of certain areas only</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-375556</link>
                        <pubDate>Thu, 18 Feb 2021 15:14:34 +0000</pubDate>
                        <description><![CDATA[Is there a way to scale certain areas only? If I scale a model on the z-axis - the whole z-axis is scaled.  I would like scale a certain area - i.e. the middle section of the model an keep t...]]></description>
                        <content:encoded><![CDATA[<p><span class="style-scope yt-formatted-string" dir="auto"> Is there a way to scale certain areas only? If I scale a model on the z-axis - the whole z-axis is scaled. </span> <span class="style-scope yt-formatted-string" dir="auto">I would like scale a certain area - i.e. the middle section of the model an keep the original dimensions of the top and lower secions.</span></p><p>Is this possible on the current PrusaSlicer or any other slicer out there?</p><p>Cheers</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>MC</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/scaling-of-certain-areas-only/#post-375556</guid>
