Scaling Object with multiple parts causing incorrect size data.
btarlton
(@btarlton)
When you add an object with multiple parts to prusa slicer and then scale the "main" object which includes everything, the size reported in the "Part Manipulation" is no longer correct for the parts.
To reproduce, just add any STL/Object to Prusa and then add a part to it like a box.  Notice the size of the box.  Then scale the "group".
You'll notice the box actually changes when you scale, but the size dimensions do not update under the "Part Manipulation" window.
And furthermore, if you manually try to set the size in milimeters manually after scaling the main object, the size value will not match the physical size.
I don't know if it's something weird I'm doing or if it's a bug??? Has anyone else seen this?
Thanks,
Barry
Posted : 06/03/2020 11:40 pm
