Scaled down slices on Prusa CORE One
johndisandonato
(@johndisandonato)
I just finished building my CORE One this weekend and find it amazing. Today I ran into a very weird issue with PrusaSlicer: all my prints are roughly but not exactly centered, surface finish is amazing, but they're scaled down by exactly 50% on all axes (with eerily high precision, I should add). I found this has happened on a couple models I designed, but then managed to reproduce it on a 10x10x10mm cube, on both my PCs -- one running CachyOS, the other Manjaro Linux, if it helps. The layers look like they're the correct height.
The plausible short term workaround is scaling to 200%, but that doesn't sound viable so I'd rather look for a real solution.
I'm not sure the couple issues I found between here and GitHub are related. Currently printing a spatula from the bgcode on the original usb drive which looks like it's printing at the correct size, so I'm guessing the gcode is not being generated correctly by the slicer. I only tried the 0.2mm SPEED profile so far.
Could this have anything to do with the print profiles updates? I noticed there was a commit from this morning but the diff isn't really legible to me and I don't know what to look for, I wonder if that might be the culprit.
Thank you in advance for your help!
A
Posted : 28/05/2025 1:27 pm
johndisandonato
(@johndisandonato)
RE: Scaled down slices on Prusa CORE One
Never mind -- I ended up clearing my configuration on both machines and now everything works as expected.
Posted : 28/05/2025 3:56 pm
