Rotate G-code Thumbnail/Rotate Import
Running a highly modified Davinci Pro, PrusaSlicer is all setup no help needed for that. Just my only thing i need help with and how i can't figure out is my home 0,0 is in the back right of printer vs the left front like most. With simplify 3d i could always import odjects 180 so that they face the front and not the back. Is this possible with PrusaSlicer. Also the same with the G-code thumbnail, it always shows the back of odject not the front, is there a way to fix this?
If there isn't a way i guess i will just change my home to be the left front, but think would be easier if this could be fixed in the software.
This topic was modified 4 years temu by PrintSomething
Opublikowany : 14/12/2022 4:39 pm
