					                		Removing a single connector after splitting without redoing all cuts - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/removing-a-single-connector-after-splitting-without-redoing-all-cuts/</link>
                <lastBuildDate>Fri, 15 May 2026 10:44:22 +0000</lastBuildDate>
                        <title>Removing a single connector after splitting without redoing all cuts</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/removing-a-single-connector-after-splitting-without-redoing-all-cuts/#post-787578</link>
                        <pubDate>Fri, 27 Mar 2026 13:52:34 +0000</pubDate>
                        <description><![CDATA[I ran into an issue while splitting a model in PrusaSlicer where one of the connector holes I placed broke through the outer surface of the model.The challenge was that I had already printed...]]></description>
                        <content:encoded><![CDATA[<p class="isSelectedEnd">I ran into an issue while splitting a model in PrusaSlicer where one of the connector holes I placed broke through the outer surface of the model.</p><p><img class="alignright size-medium wp-image-185556" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/b4044dea-offending-connetor-600x460.png" alt="" width="400" height="307" /></p><p class="isSelectedEnd">The challenge was that I had already printed multiple parts (8 pieces) when I noticed the problem. I needed to remove the connector hole to restore the original surface contour, but redoing all the cuts wasn’t really an option since the connectors would no longer align.</p><p class="isSelectedEnd">At first, it seemed like there was no way to edit or remove connectors after additional cuts had been made. The connectors showed up in the object list as a group, but I couldn’t modify them.</p><p class="isSelectedEnd"><strong>What worked for me:</strong></p><ul><li>I duplicated the project to avoid breaking anything</li><li>Then I deleted one of the later cut sections</li><li>I received a warning: “Delete object which is part of a cut object”, but proceeded anyway</li><li>After deleting that section, the connectors from the cuts became accessible again in the right-hand panel</li><li>I was then able to select and delete just the one connector that was causing the issue</li></ul><p class="isSelectedEnd">This allowed me to remove the unwanted hole while keeping the rest of the connectors aligned with the parts I had already printed.</p><p>Hopefully this helps someone avoid having to redo an entire multi-part split.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/db2c9628-1-cut-object-warning.png"><img class="size-medium wp-image-185554 alignleft" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/db2c9628-1-cut-object-warning-600x456.png" alt="" width="400" height="304" /></a></p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/0875022b-connection-access.png"><img class="size-medium wp-image-185555" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/0875022b-connection-access-600x500.png" alt="" width="400" height="333" /></a></p>
<div id="wpfa-185557" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1774619554-16d38b80-offending-connetor.png" target="_blank" title="16d38b80-offending-connetor.png"><i class="fas fa-paperclip"></i>&nbsp;16d38b80-offending-connetor.png</a></div>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Virgil</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/removing-a-single-connector-after-splitting-without-redoing-all-cuts/#post-787578</guid>
