PS on extruder does not heat up, and strange behaviour of infill
Mike
 Mike
(@mike-25)
Hi
I have some trouble with an object which is to be printed with dual extrusion (PLA on extr1 and PVA on extr2). There are 2 problems:
1. It is printed with both extruders, but extr2 does not heat up. The temp for PVA is 210C, and there is no hardware problem with the extruder. What is wrong in my settings so that ext2 is selected but receives no command to heat up at the beginning of layer 27 (see project file)
2. The infill of the cylinder (see image) should be all 25%, as set for the entire object. However the left side shows solid infill as if it was approaching a horizontal shell, which is not the case.
Thanks for your help!
Mike
(Mark the solid infill (left) in the cylinder, which should be non-solid like the right side of the cylinder)
test_001.3mf
PrusaSlicer
Version: 2.3.0-alpha2+linux-x64
Build: PrusaSlicer-2.3.0-alpha2+linux-x64-202010241644
Operating System: Unix
System Architecture: 64 bit
System Version: Linux 4.19.0-12-amd64 x86_64
Total RAM size [MB]: 16,518MB
OpenGL installation
GL version: 3.0 Mesa 18.3.6
Vendor: Intel Open Source Technology Center
Renderer: Mesa DRI Intel(R) UHD Graphics 630 (Coffeelake 3x8 GT2)
GLSL version: 1.30
This topic was modified 5 years ago by Mike
Version: 2.5.0+linux-x64-GTK3
Build: 202209060725
Operating System: Debian Linux
Posted : 10/11/2020 10:48 pm
Mike
 Mike
(@mike-25)
RE: PS one extruder does not heat up, and strange behaviour of infill (partly solved)
My second question about the spontaneous solid infill appeared to be caused by the setting solid-infill-treshold-area. This was default set to 70mm2. I was not aware of the existence of this setting. After reducing the pct to 10mm2 all internal space was nicely filled with the correct infill.
Build: 202209060725
Posted : 11/11/2020 11:27 pm
