					                		Prusaslicer vs Cura surface finish? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/</link>
                <lastBuildDate>Thu, 21 May 2026 20:42:19 +0000</lastBuildDate>
                        <title>RE: Prusaslicer vs Cura surface finish?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-470287</link>
                        <pubDate>Sat, 10 Jul 2021 21:23:24 +0000</pubDate>
                        <description><![CDATA[Posted by: @sammyv Thanks for the tip on over extrusion.  I went and did a precise-method 40-40 cube, and had a wall thickness of .51 (target was .40!), so a few iterations and reduced my ex...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="252553" data-postid="469927" data-mention="sammyv"><div class="wpforo-post-quote-author"><strong> Posted by: @sammyv </strong></div><p>Thanks for the tip on over extrusion.  I went and did a precise-method 40-40 cube, and had a wall thickness of .51 (target was .40!), so a few iterations and reduced my extrusion multiplier from 1.0 to 0.75.  SO much better now - best I've seen in a long time.</p></blockquote><p>Glad it's working, but a reduction down to 0.75 is pretty extreme. Keep an eye out for other possible problems. Do the Prusa-supplied gcode samples print out normally? If so, go through your slicer settings to see if something is throwing the extrusion rates off.</p><blockquote data-userid="252553" data-postid="469927" data-mention="sammyv"><p>Going forward, going to add extruder calibration step to any change in filament.  Oh, and only using Prusaslicer, not bothering to test it out with Cura. </p></blockquote><p>I definitely recommend doing so. There can be 1-3% variations that make a huge difference for fine stringing and other common problems.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>bobstro</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-470287</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-470257</link>
                        <pubDate>Sat, 10 Jul 2021 19:26:11 +0000</pubDate>
                        <description><![CDATA[@sammyv Just an FYI, the default extrustion width for a 0.4 nozzle in prusaSlicer is 0.45 not 0.4, unless you decidedly changed it you were most likely shooting for the wrong target. if you ...]]></description>
                        <content:encoded><![CDATA[<p>@sammyv</p><p> </p><p>Just an FYI, the default extrustion width for a 0.4 nozzle in prusaSlicer is 0.45 not 0.4, unless you decidedly changed it you were most likely shooting for the wrong target. if you find that your under extruding at some point you may want to try and recalibrate for 0.45</p><p> </p><p>Good luck, glad to hear your prints are looking better.</p><p> </p><p>Swiss_Cheese</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Swiss_Cheese</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-470257</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-469927</link>
                        <pubDate>Sat, 10 Jul 2021 01:40:43 +0000</pubDate>
                        <description><![CDATA[Thanks for the tip on over extrusion.  I went and did a precise-method 40-40 cube, and had a wall thickness of .51 (target was .40!), so a few iterations and reduced my extrusion multiplier ...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the tip on over extrusion.  I went and did a precise-method 40-40 cube, and had a wall thickness of .51 (target was .40!), so a few iterations and reduced my extrusion multiplier from 1.0 to 0.75.  SO much better now - best I've seen in a long time.</p><p>Going forward, going to add extruder calibration step to any change in filament.  Oh, and only using Prusaslicer, not bothering to test it out with Cura. </p><p>So yeah, user error.</p><p>Thanks for the help!</p><p>-S</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>SammyV</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-469927</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-468334</link>
                        <pubDate>Tue, 06 Jul 2021 15:56:38 +0000</pubDate>
                        <description><![CDATA[Neither of your results is particularly good. Both show signs of over extruding. The PrusaSlicer example is simply worse. It&#039;s hard to guess at what&#039;s going on, but suffice to say, PrusaSlic...]]></description>
                        <content:encoded><![CDATA[<p>Neither of your results is particularly good. Both show signs of over extruding. The PrusaSlicer example is simply worse. It's hard to guess at what's going on, but suffice to say, PrusaSlicer can produce far better results than what you're getting. Save your current<span class="Apple-converted-space">  </span>3MF project file, zip it up, and attach it to a reply here so we can see your part &amp; settings and give better recommendations.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-468334</guid>
                        <title>Prusaslicer vs Cura surface finish?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-468130</link>
                        <pubDate>Mon, 05 Jul 2021 23:12:15 +0000</pubDate>
                        <description><![CDATA[HI there.Any idea why prusaslicer (tuned) is delivering such dramatically poor surface quality compared to defaults in Cura? See attached. (prusaslicer on the left)    I&#039;ve been a long time ...]]></description>
                        <content:encoded><![CDATA[<p>HI there.</p><p>Any idea why prusaslicer (tuned) is delivering such dramatically poor surface quality compared to defaults in Cura? See attached. (prusaslicer on the left) </p><p> </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2021/07/Left-is-prusa-right-is-cura.jpg"><img class="alignnone size-medium wp-image-95725" src="https://forum.prusa3d.com/wp-content/uploads/2021/07/Left-is-prusa-right-is-cura-600x500.jpg" alt="" width="600" height="500" /></a></p><p> </p><p> </p><p>I've been a long time prusaslicer user, gave up in Cura over a year ago because it was doing something very erratic. I could not get the print surface for these lids to look good, so in a whim downloaded Cura, added my Artillery Sidewinder using the default settings and generic PLA settings and printed the output gcode. And it's so much better than I got with Prusaslicer after a few iterations.(my Sidewinder isn't even stock - genuine E3d titan aero and hardened nozzle, skr 1.4 board) </p><p> </p><p>My next step is to try to dissect the Cura settings and replicate in PS to see if I can find something interesting.</p><p> </p><p>Would like to know if any of you have had similar experiences and any hints as to what I might ben doing wrong.</p><p>Thanks</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-vs-cura-surface-finish/#post-468130</guid>
