Prusaslicer upgrade on MacOS
Bob
 Bob
(@bob-2)
Last spring I upgraded to 2.2.0.  I'm now trying to upgrade to 2.3.0, I really want the paint on support feature.  When I tried to install the DMG package it asked me if I want to replace or merge.  I figured merge would be better as I didn't want to lose my setting, however when I opened PrusaSlicer after the "upgrade" it was still reporting 2.2.0.  I tried again, this time I selected replace and after it finished I once again opened PrusaSlicer and it was still reporting 2.2.0.
What the hell do I need to do to upgrade to 2.3?  I don't understand this behavior, I've been using PrusaSlicer for 4 years and this is the only time I've had an upgrade in place fail.
Regards
-Bob
Veröffentlicht : 21/03/2021 1:15 am
tentaclejoe
(@tentaclejoe)
Mitglied
RE: Prusaslicer upgrade on MacOS
Have you checked your Applications folder for 2 versions of the software since you chose merge?
Veröffentlicht : 21/03/2021 8:30 pm
Bob
 Bob
(@bob-2)
Yes, I only find one version.  I've searched my drive and find only one, the one I installed on 3.20.2020
-Bob
Veröffentlicht : 22/03/2021 1:53 am
towlerg
(@towlerg)
How about saving your config and profiles File/Export/Export config bundle with physical printer, uninstall, download (just to be sure), reinstall and import everything you saved File/Import/Import bundle.
Veröffentlicht : 22/03/2021 10:00 am
Bob
 Bob
(@bob-2)
I tried that, I uninstalled but didn't empty the waste basket and it didn't help.  When it didn't add the new version I pulled 2.2 out of the waste basket.
-Bob
Veröffentlicht : 23/03/2021 10:33 pm
tentaclejoe
(@tentaclejoe)
Mitglied
Have you checked both Applications folders on your system? There is one under Macintosh HD/Applications and one in your user folder Macintosh HD/Users/User_Name/Applications
Veröffentlicht : 24/03/2021 12:36 am
towlerg
(@towlerg)
@bob-2
Sorry, I don't know much bout Macs. On windows there is an app called Everything, find all dir/file names the meet specified. Uninstall and search for PrusaSlicer and in particular make sure you delete all occurrences of Prusaslicer.ini, several peeps have had install problems if existing .ini file is corrupt.
Veröffentlicht : 24/03/2021 7:53 am
Mitglied
Export you settings and then replace.
Veröffentlicht : 24/03/2021 9:40 am
