					                		PrusaSlicer Test Report: Filament List &amp; Usability Issues - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-test-report-filament-list-usability-issues/</link>
                <lastBuildDate>Sat, 13 Jun 2026 03:02:08 +0000</lastBuildDate>
                        <title>RE: PrusaSlicer Test Report: Filament List &amp; Usability Issues</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-test-report-filament-list-usability-issues/#post-758316</link>
                        <pubDate>Sun, 20 Jul 2025 19:42:23 +0000</pubDate>
                        <description><![CDATA[I&#039;m afraid you are posting in the wrong place.  This is a user to user forum and the Dev&#039;s don&#039;t use here.
Anything Prusa related must be posted over at their official github.
For prusa ...]]></description>
                        <content:encoded><![CDATA[I'm afraid you are posting in the wrong place.  This is a user to user forum and the Dev's don't use here.
For prusa slicer related issues that is located here https://github.com/prusa3d/PrusaSlicer/issues  
For settings specific issues that is https://github.com/prusa3d/PrusaSlicer-settings/issues
Please follow the submission guidelines and please do a search of both OPEN and CLOSED issues before opening new ones.  There are over 4.9K open ones already and over 8.5k closed ones so a lot of ground has already been covered.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-test-report-filament-list-usability-issues/#post-758316</guid>
                        <title>PrusaSlicer Test Report: Filament List &amp; Usability Issues</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-test-report-filament-list-usability-issues/#post-758295</link>
                        <pubDate>Sun, 20 Jul 2025 18:13:17 +0000</pubDate>
                        <description><![CDATA[🧪 PrusaSlicer Test Report: Filament List &amp; Usability IssuesIssue Summary The selectable filament list under the filament tab is shorter than the list used for filament comparisons, which...]]></description>
                        <content:encoded><![CDATA[<p>🧪 PrusaSlicer Test Report: Filament List &amp; Usability Issues</p><p><strong>Issue Summary</strong> The selectable filament list under the filament tab is shorter than the list used for filament comparisons, which results in unnecessary steps and configuration overhead. Additionally, the lack of a scrollbar and case-insensitive search functionality makes navigation inefficient.</p><p><strong>Steps to Reproduce</strong></p><p>Open PrusaSlicer and go to the Filament tab.</p><p>Attempt to select a filament from the predefined list.</p><p>Compare this list with the filament comparison list (e.g., from the Prusa Materials Guide).</p><p>Notice missing entries.</p><p>Try searching by name using different letter cases ("PETG" vs "petg")—results aren't found unless casing matches exactly.</p><p>Scroll down the filament selection pane—note there's no scrollbar, requiring tedious mouse-wheel scrolling.</p><p><strong>Expected Behavior</strong></p><p>The selectable filament list should include all filaments available for comparison.</p><p>A scrollbar should appear for long lists.</p><p>Search functionality should be <strong>case-insensitive</strong> and responsive to partial matches.</p><p><strong>Current Workaround</strong> To access missing filaments, users must:</p><p>Create a custom filament profile manually</p><p>Copy and paste settings from comparison data</p><p>Save and reimport it for slicing</p><p>This adds unnecessary complexity for users who rely on efficient workflows.</p><p> </p><p>🧪 Rapport de test PrusaSlicer : Problèmes de liste de filaments et d'utilisabilité</p><p><strong>Résumé du problème</strong> La liste de filaments sélectionnables est inférieure à celle utilisée pour les comparaisons, ce qui génère des manipulations inutiles. De plus, l’absence de poignée de défilement et de recherche insensible à la casse complique l’utilisation.</p><p><strong>Étapes pour reproduire</strong></p><p>Ouvrez PrusaSlicer et allez dans l’onglet Filaments.</p><p>Essayez de sélectionner un filament depuis la liste prédéfinie.</p><p>Comparez cette liste avec celle du guide des matériaux Prusa.</p><p>Certains filaments sont manquants.</p><p>Tentez une recherche avec des noms en casse différente ("PETG" vs "petg")—aucun résultat si la casse ne correspond pas.</p><p>Essayez de faire défiler la liste—aucune poignée n’apparaît, le défilement est fastidieux.</p><p><strong>Comportement attendu</strong></p><p>La liste de filaments devrait inclure tous les matériaux disponibles.</p><p>Une barre de défilement devrait apparaître pour les longues listes.</p><p>La recherche devrait être <strong>insensible à la casse</strong> et plus fluide.</p><p><strong>Solution de contournement actuelle</strong> Pour accéder aux filaments manquants :</p><p>Créer un profil de filament personnalisé</p><p>Transférer les réglages depuis les données de comparaison</p><p>Sauvegarder et réimporter pour l’utilisation</p><p>Cela ajoute une complexité inutile pour les utilisateurs avancés comme débutants.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Laurent Khiati</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-test-report-filament-list-usability-issues/#post-758295</guid>
