Prusaslicer Profile for BIQU BX
Pagina 1 / 2
Utenti
Has anyone set this printer up with Prusa Slicer?
Postato : 15/03/2021 1:30 am
RE: Prusaslicer Profile for BIQU BX
Looks like an Ender with significant upgrades. Definitely an interesting beast. Let us know how you get on with it!
I don't have a pre-built profile, but I'd be happy to help you start one if you don't have any other luck. You can get a running start by entering the values from issuing the M503 gcode command and extracting the start and end gcode from a sample gcode file. I was able to get my Sidewinder working well with PrusaSlicer quickly this way.
Postato : 15/03/2021 5:22 am
Utenti
I will post an update here as I get it to work.
Postato : 15/03/2021 1:05 pm
hedensted
(@hedensted)
I have the B1, my first printer, currently using cura. But i like to try out pursa, I just downloaded it, it's a bit overwhelming, did you set up a profil you can share?
Postato : 11/04/2021 7:13 am
EpicMount
(@epicmount)
@cwbullet
I just received my BIQU BX. I'll be happy to test your printer profile once you have it ready.
Postato : 23/04/2021 2:33 am
Utenti
@kmount
I do not have one.  I have been looking for one for PrusaSlicer.  A lot of folks have said just use the Mk3S and adjust it.
Postato : 23/04/2021 2:39 am
Utenti
I have been using this printer for 2 months.  It is not a Prusa, but it is pretty darn good.  I have a Cura Profile but need to develop one for prusa slicer.
Postato : 24/05/2021 2:04 am
Posted by: @cwbullet
I found that starting with the values returned by M503 is a good place to start. The firmware settings for maximum feed rates, acceleration, and jerk are usually a bit optimistic but help as a starting point. After that, it's mostly a question of translating the start gcode (placeholders) into PrusaSlicer/Slic3r syntax.
Postato : 24/05/2021 3:31 am
Utenti
M503 - Report Settings
EEPROM Report all settings that may be saved to EEPROM.   It will print a concise report of all current settings (in SRAM) to the host console.
Just posting for those that might want to know what this is.
Postato : 24/05/2021 10:09 am
Utenti
BIQU BX
I am working on a Prusaslicer profile.  I will post it when complete.  It is nto perfect but I started with the ender like recommended above.
Postato : 30/09/2021 4:25 pm
BUNNFRED
(@bunnfred)
Hi, does anyone have a decent prusaslicer profile for the biqu bx so far? Still looking for one which works.
Postato : 17/11/2021 11:30 am
Utenti
I am also looking for one.  I have one that works, but I not happy with ti yet.
Postato : 17/11/2021 4:29 pm
BUNNFRED
(@bunnfred)
Would you still like to share it?
Postato : 18/11/2021 8:15 am
zuul47
(@zuul47)
Looking for one for PrusaSlicer. Let me know how it's going with the one you are creating.
Postato : 29/12/2021 8:23 pm
rubino25
(@rubino25)
Hi, any news for the profile?
Postato : 06/04/2022 5:25 pm
Utenti
Nope.  Never could it perfected so I use Cura for my BX.
Postato : 06/04/2022 5:37 pm
rubino25
(@rubino25)
Tanks! So, with cura it's "perfect"?
Postato : 06/04/2022 5:45 pm
rubino25
(@rubino25)
So, i get a realy decent profile in prusaslicer that works great. Some tuning to do but hey, it works!
Postato : 08/04/2022 5:48 am
Utenti
What did you use as a starting point?
Posted by: @arubino25
Postato : 09/04/2022 1:26 pm
rubino25
(@rubino25)
The latest Ender 3 S1 profile.
https://www.mediafire.com/file/grteknrfyj7n9ps/PrusaSlicer.rar/file
Heare you have the "printer" and "print" folder of PrusaSlicer in  "C:\Users\"user"\AppData\Roaming\PrusaSlicer"
Edit: Using with Klipper firmware and NON stock dimension and harware. I've updated the 20X40 vertical bar to 420mm from an old printer and mounted the original superpinda sensor.
Questo post è stato modificato 4 years fa da rubino25
Postato : 09/04/2022 1:44 pm
Pagina 1 / 2
