Prusaslicer Profile for BIQU BX
Has anyone set this printer up with Prusa Slicer?
RE: Prusaslicer Profile for BIQU BX
Looks like an Ender with significant upgrades. Definitely an interesting beast. Let us know how you get on with it!
I don't have a pre-built profile, but I'd be happy to help you start one if you don't have any other luck. You can get a running start by entering the values from issuing the M503 gcode command and extracting the start and end gcode from a sample gcode file. I was able to get my Sidewinder working well with PrusaSlicer quickly this way.
I will post an update here as I get it to work.
I have the B1, my first printer, currently using cura. But i like to try out pursa, I just downloaded it, it's a bit overwhelming, did you set up a profil you can share?
@cwbullet
I just received my BIQU BX. I'll be happy to test your printer profile once you have it ready.
@kmount
I do not have one. I have been looking for one for PrusaSlicer. A lot of folks have said just use the Mk3S and adjust it.
I have been using this printer for 2 months. It is not a Prusa, but it is pretty darn good. I have a Cura Profile but need to develop one for prusa slicer.
I found that starting with the values returned by M503 is a good place to start. The firmware settings for maximum feed rates, acceleration, and jerk are usually a bit optimistic but help as a starting point. After that, it's mostly a question of translating the start gcode (placeholders) into PrusaSlicer/Slic3r syntax.
BIQU BX
I am working on a Prusaslicer profile. I will post it when complete. It is nto perfect but I started with the ender like recommended above.
Hi, does anyone have a decent prusaslicer profile for the biqu bx so far? Still looking for one which works.
I am also looking for one. I have one that works, but I not happy with ti yet.
Would you still like to share it?
Looking for one for PrusaSlicer. Let me know how it's going with the one you are creating.
Hi, any news for the profile?
Nope. Never could it perfected so I use Cura for my BX.
Tanks! So, with cura it's "perfect"?
So, i get a realy decent profile in prusaslicer that works great. Some tuning to do but hey, it works!
What did you use as a starting point?
The latest Ender 3 S1 profile.
https://www.mediafire.com/file/grteknrfyj7n9ps/PrusaSlicer.rar/file
Heare you have the "printer" and "print" folder of PrusaSlicer in "C:\Users\"user"\AppData\Roaming\PrusaSlicer"
Edit: Using with Klipper firmware and NON stock dimension and harware. I've updated the 20X40 vertical bar to 420mm from an old printer and mounted the original superpinda sensor.
