PrusaSlicer on the MacBooPro.... troubles....
generall
(@generall)
I have issues with the PrusaSlicer on my Macbook Pro 2022 M1Pro:
When using the Funktion: Repair a stl file - it repairs it - but afterwards the software  cannot load the resulted new obj file -message error in file (on the Windows Version it works flawless to my best satisfaction)
Same when right clicking in the right side objekt list - for correction..
This happens only on the MAC - i am modelling  with Sketchup3d 23 and archicad 26  - the problem comes with the two sources.
Napsal : 20/07/2023 10:28 am
RE: PrusaSlicer on the MacBooPro.... troubles....
The windows version has Repair through Netfabb available as an option.  This is not available on any other OS.  Netfabb repairs tend to work better as its a third party service that is accessed through the windows OS.  There is no way to access that on other versions.
You will have to use some other repair software on other operating systems or better yet learn what is wrong with your models or the export settings so you can fix them at source (if they are your own models).  It is far better to produce valid manifold error free geometry than to rely on something else to fix them for you.
Napsal : 20/07/2023 11:28 am
