PrusaSlicer leaving items off when sliced
When I drop the STL file created on Sketchup into the PrusaSlicer it shows up in the 3d model just as I designed it. When I slice it, the slicer leaves off a portion of the design, specifically the bottom words. See images below. Why does it do that? How can I fix that? Thanks in advance for the help.
Cheers, TK
Postato : 01/01/2022 10:49 pm
RE: PrusaSlicer leaving items off when sliced
Did you try enabling detect thin walls? Also adding a positive value for xy compensation is worth a try.
Mk3S+,SL1S
Postato : 01/01/2022 10:53 pm
1 persone hanno apprezzato
Topic starter
answered:
You're a genius! It worked! Thank you so much.
Postato : 01/01/2022 11:04 pm
Features are too small to print for standard settings for the 0.4 nozzle.
Postato : 02/01/2022 12:54 am
