PrusaSlicer Improvement Suggestion
Klaas
(@klaas)
Rotation Mode Column colours
Like the coloured manipulation arrows on the plater in Rotation mode, it would make PrusaSlicer even more user friendly by making the X Y Z COLUMNS at the bottom-right of the screen also the same colour RED - GREEN and BLUE .
Posted : 17/09/2019 5:51 am
RE: PrusaSlicer Improvement Suggestion
That is a great idea.
Posted : 17/09/2019 1:09 pm
Snype
(@snype)
Testing routines such as: Temperature Towers, String Tests and such.
Testing filament and settings before big prints is a general routine.  It'd be nice if we didn't have to manually G-Code it and was able to use a consistent standard.
I'd also like to use Tree Supports.
What I want most is a manual.  There are so many settings I wish I knew what they were.
Posted : 18/09/2019 2:53 am
gregorygseb
(@gregorygseb)
When printing multiple objects it would be nice to have the option of having the nozzle complete the layer on the next object that is closest to the object it is currently printing. For example if I'm printing 3 cubes; CubeA, CubeB, CubeC and I line them up on the print bed in order, then I would want the printer to print the layer on CubeA then CubeB then CubeC. But what happens often is that it will print the layer on CubeA, jump over CubeB and goto CubeC before going back to CubeB. When I print a large number of objects this seems to be a waste of long fast movements.
Posted : 20/10/2019 12:15 am
