PrusaSlicer first line on other printers
Ondrej Rafaj
(@ondrej-rafaj)
hey guys, any way how to add that dual cleaning line I get on my MK3s at the front of my bed before the print starts on my new CR10Max? I setup a new printer profile there but id won't do that first run so first few cm of my print are screwed a bit (missing filament)
Napsal : 03/04/2020 3:04 pm
RE: PrusaSlicer first line on other printers
Copy the Mk3 Start code into the CR10 Custom Gcode Start code area.
Mk3S Custom Gcode, Start code
M862.3 P "[printer_model]" ; printer model check   >>Mk3 specific, not needed on CR10
M862.1 P[nozzle_diameter] ; nozzle diameter check  >>Mk3 specific, not needed on CR10
M115 U3.8.1 ; tell printer latest fw version  >>Mk3 specific, not needed on CR10
M83 ; extruder relative mode
M104 S[first_layer_temperature] ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] ; wait for extruder temp
G80 ; mesh bed leveling>> does your CR10 do mesh bed levelling
G1 Y-3.0 F1000.0 ; go outside print area
G92 E0.0
G1 X60.0 E9.0 F1000.0 ; intro line   >>>>> the green text is your Intro line Gcode add this after your CR10 Auto home commandand heating commands
G92 E0.0
M221 S{if layer_height<0.075}100{else}95{endif}  >>this reduces the extrusion slightly by setting the Flow value to 95% for layer heights above 0.075mm
Regards Joan
Napsal : 03/04/2020 4:53 pm
Heres the start of what I use on My cr10S
M117 Clean ; Indicate nozzle clean in progress on LCD
M107 ; Turn layer fan off
G21 ; Set to metric, change to G20 if you want Imperial
G90 ; Force coordinates to be absolute relative to the origin
G28 ; Home X/Y/Z axis
G0 X1 Y0 Z0.16 F9000 ; Move in 1mm from edge and up z 0.15mm
G92 E0 ; Set extruder to 0 zero
G1 Y145 E50 F500 ; Extrude 50mm filiment along Y axis 145mm long to prime and clean the nozzle
G92 E0.0 ; Reset extruder to 0 zero end of cleaning run
;G1 E-1 F5000 ; Retract filiment by 1 mm to reduce string effect
G1 X3 Y145 Z15 F9000 ; Move over and rise to safe Z height
G1 X3 Y0 Z15 F9000 ; Move back to front of bed at safe Z height to shear strings
Only difference is it puts the purge line up the left hand side instead.
Napsal : 03/04/2020 5:09 pm
