PrusaSlicer crashes when Exporting config bundle
paul.c37
(@paul-c37)
When I try to export the config bundle from Prusa Slicer so I can import it on another machine, it gets part way through the export, and then crashes. The software just closes down, and the export is incomplete.
Running build PrusaSlicer-2.0.0+win64-201905201652
I have tried this with a clean install on a new machine and the result is always the same.
It appears to stop at the same point every time as it starts writing the presets section:
[presets]
print = (0.15mm QUALITY MK3)
sla_prin
Thank you
Paul
Posted : 27/07/2019 10:59 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
RE: PrusaSlicer crashes when Exporting config bundle
It is a known issue, it will be fixed in the upcoming PrusaSlicer 2.1.
Posted : 29/07/2019 7:56 am
