Prusaslicer Crashes upon slicing any model.
Gabe Hutsects
(@gabe-hutsects)
Version 2.3.0
Linux Desktop 5.11.10-1-MANJARO #1 SMP PREEMPT Thu Mar 25 17:14:55 UTC 2021 x86_64 GNU/Lin
So, prusa slicer crashes on trying to slice every model, every time.  If i remove the infill, it stops crashing.  Literally was working fine two days ago the last time I touched it.
I have tried to get more info, but I cannot get it to output to a log file for some reason. using this command:
prusa-slicer --loglevel 5 --output prusalog.txt
The output log stays empty on crash.
Any idea on what's going on here?
Very frustrating to have this break entirely overnight.
Posted : 11/04/2021 8:59 pm
Gabe Hutsects
(@gabe-hutsects)
RE: Prusaslicer Crashes upon slicing any model.
I also tried to build the latest RC from the AUR, however the build failed for reasons I don't have the knowledge to decipher.
I also tried to roll back to the previous version, and there are dependencies I will have to try and find out how to deal with another time.
Seeing as how the cura interface fails to run on linux entirely, and there are not many real slicers that run on linux,  I now have $2700 dollars worth of bricks because of the botched update...   I literally don't know what to say. Now I am literally going to have to waste a ton of time figuring out work a work around because this was pushed out without proper testing for some reason.   Keep in mind, this prusa slicer update is from the official packages, so that means it's been finalized in github, and finalized in the arch official repositories, but it literally doesn't even work. never should have been pushed out as an update to the linux platform as a whole.
Posted : 12/04/2021 12:57 am
This is a user to user forum.  You need to address your concerns on github.  https://github.com/prusa3d/PrusaSlicer/issues
Posted : 12/04/2021 6:15 am
joeybronzoni
(@joeybronzoni)
Posted by: @gabe-hutsects
Version 2.3.0
Yep I am running vanilla Arch and have the same issue. I'm looking into now. But just stopped by to see if anyone had the same issues. After slicing a model it hangs a bit and then crashes and the screens(4 monitors)go black and then when they come back on its frozen this is with 32-core CPU.
Posted : 11/02/2022 2:31 am
merijn
(@merijn)
Running prusa slicer 2.4.1.
It not just crashes prusa-slicer itself, it crashes my whole operating system (Arch). It just has become unusable for me.
Posted : 10/04/2022 8:56 am
joeybronzoni
(@joeybronzoni)
What GPU setup do you have. I was having that issue running a mix of both nvidia and AMD GPUs. Once I swtiched to all AMD(or all nvidia) the problem stopped.  This was the github issue where we it was talked about: https://github.com/prusa3d/PrusaSlicer/issues/7845
This post was modified 4 years ago by joeybronzoni
Posted : 10/04/2022 1:35 pm
