PrusaSlicer - Brim skipped when using multiple build plates
When I slice any object with an activated brim and that brim would happen to sit over the digit on the build plate which is shown when multiple build plates are used, the brim around the digit is skipped in the display. But the exported gcode contains the brim as expected.
Can you confirm this behaviour?
Questa discussione è stata modificata 8 months fa da Xargas
Postato : 30/01/2025 10:34 am
Topic starter
answered:
RE: PrusaSlicer - Brim skipped when using multiple build plates
Addition: I created a report here: https://github.com/prusa3d/PrusaSlicer/issues/14059 (Edit was not possible, so the double post)
Postato : 30/01/2025 10:51 am
Its a known issue, https://github.com/prusa3d/PrusaSlicer/issues/13814 just a visual bug that will be fixed in a later release (at some point).
Postato : 30/01/2025 10:52 am
Topic starter
answered:
Thanks for the link, I searched for "multiple plates" but did not find any issue. Ok, then I can mark it as duplicate 🙂
Questo post è stato modificato 8 months fa da Xargas
Postato : 30/01/2025 10:58 am
