PrusaSlicer 2.9 seems to ignore bridge direction.
Nanoplane
(@nanoplane)
I have a long part that includes a 10mm wide cavity that runs just below the surface for the full length of the part. Regardless of what I set the bridging angle to, the bridging is generated along the long direction of the cavity.. it' seems to be shown in the resulting code as solid infill rather than bridging...
How can I get it to change the direction of the bridging?
I can "fix" the issue by adding a modifier.. The modifier seems to honor the bridging direction... and it is shown as Bridging infill... but, shouldn't it work on the main part?
Postato : 25/01/2025 7:12 pm
RE: PrusaSlicer 2.9 seems to ignore bridge direction.
It should. Would you please upload a 3mf project file (zip compressed, or the forum software will silently ignore it) so we we can see your settings and the model topology? Use the Attach file button below the post edit window.
Postato : 25/01/2025 8:46 pm
Nanoplane
(@nanoplane)
cover-PTest.3mf
In this test, it doesn't seem to matter what I set the Bridging angle to... the result is the same..
Postato : 26/01/2025 4:24 am
Snuffleupagus
(@snuffleupagus)
Utenti
@nanoplane
         If you add at least one bottom layer, I'd recommend more if your project can afford it.
Print Settings>Layers and perimeters>[Horizontal shells] Solid layers: Bottom: (set to at least one layer)
Then go to Print Settings>Infill>[Advanced]Bridging angle: and set it to 135 degrees
I would also recommend turning on "Detect bridging perimeters:" and if your going  to be using FLEX material you may want to give consideration to enabling "Avoid crossing perimeters:"
Good luck, I hope this helps
Postato : 26/01/2025 7:12 am
Nanoplane
(@nanoplane)
The lack of a bottom layer was intentional.. wanted to get as close as possible to a simple shell. I've tried changing the bridging angle but it seems to have no effect.. hence the post 🙂
Postato : 26/01/2025 3:59 pm
From the preview it looks like the slide doesn't see it as a bridge but infill.
Postato : 26/01/2025 4:05 pm
It wont.  Without a bottom layer, by definition it can't be a bridge.  At least as far as PS is concerned.  It only bridges the bottom of a shell, and even then only when it can do so.  At least on the exterior of objects.
Id use a modifier to set the bottom layers to zero on the actual bottom but still have 1 or more on that top section to allow bridging to be generated.
Postato : 26/01/2025 5:25 pm
Nanoplane
(@nanoplane)
So, depending on what you do, you can get weird results ... PS wants to print some internal fill floating in the air.. not sure how that's supposed to work.  🙂
I think I do have what I want.. here's my final result:
cover.3mf
At the top of the cavity is the bridge, properly oriented across the cavity, not along the length of the cavity..
There's a few "extras" on this:  it's printing with a single perimeter for the vertical and top layers, no bottom layer; There are modifiers to make the overhang on the left and right sides of the shell 2 vertical perimeters; and, there's a modifier to max sure the top of the cavity is solid / no infill.
Postato : 26/01/2025 7:27 pm
Snuffleupagus
(@snuffleupagus)
Utenti
@nanoplane
Your side (left and Rt) modifiers are causing a problem the way you implemented them you may notice they are cutting thorough your model in the intersecting areas.
The top modifier is creating an extrusion of overhanging "solid fill" (not good) with not much Infill/perimeters overlap: (also not good) this would be prone to failure with PLA and will almost certainly fail using a FLEX filament.
Once again I recommend:
I would also recommend setting "Detect bridging perimeters:" and if your going to be using FLEX material you may want to give consideration to enabling "Avoid crossing perimeters:" set to Zero, not 30.
Then remove the bottom most layer using a "Height range modifier" set to a range of 0.00-0.35mm with the property Bottom solid layers: set to zero
This avoids all the problems  and removes the bottom most layer you wanted gone. The upper area will then bridge properly as well
Good luck
Questo post è stato modificato 1 year fa da Snuffleupagus
Postato : 26/01/2025 7:50 pm
Nanoplane
(@nanoplane)
Ok, set it up as you advised... and I can't seem to get rid of a bridging layer at 4.75mm. it seems to be there to hold up the bottom of the cavity, but it's not required....
In a previous incarnation, I didn't have it there and I can't remember how I did it.... 🙁
Postato : 26/01/2025 11:15 pm
Nanoplane
(@nanoplane)
cover 2.3mf
Latest version with the large bridge at 4.75mm
Postato : 27/01/2025 12:25 am
Snuffleupagus
(@snuffleupagus)
Utenti
@nanoplane
I'm not sure I understand exactly what your after, but maybe this example will help you.
Cover_Snuff.zip
Regards
Postato : 27/01/2025 9:48 pm
Snuffleupagus
(@snuffleupagus)
Utenti
@nanoplane
I opened the Cover_Snuff.zip that I posted earlier to find that Slicer did not treat the settings I had applied the same upon Re-slicing, In fact slicer had reverted to it default behavior as though I had not applied any modifiers at all (although they are still there).
So for the amusement of all who are interested, I'm including images and an exported gcode showing the result that I can get and reproduce, but apparently cant save.
Cover_gcode_Snuff.zip
Supposed Bridging
Supposed Solid Fill
Supposed Top Fill
You can see this in the attached gcode file.
Anyway the point of this, was to help you sort out your bridging issue in 2.9.0, and it can be sorted, but Slicer is going to arm wrestle you for it.
I tend to use older versions of Slicer when I can, to avoid these kind of issues, but i understand that's not always possible.
Good Luck
Postato : 28/01/2025 12:39 am
