PrusaSlicer 2.9.2 not showing the main window
Rob Welch
(@rob-welch)
Without updating anything on my computer (Ubuntu 20.4) PrusaSlicer 2.9.2 now has nothing but a white window on the Plater tab.  All other tabs work great.
Is this some new feature Prusa is providing me?  I can still add STL files, but I can't slice, because there's no dimensions.
Do I need to try the Online version I got an email about a couple days ago?
Opublikowany : 04/06/2025 8:10 pm
Reini
(@reini-2)
RE: PrusaSlicer 2.9.2 not showing the main window
I got the same problem on Fedora 42 if you mean this:
Opublikowany : 10/06/2025 4:20 pm
Sembazuru
(@sembazuru)
Don't know if it is the same problem, but I was getting something similar on my RPi500 with the flatpack install. Seems Raspian doesn't have the required OpenGL version. But launching with the following gets it to work on my RPi500:
flatpak run --env=MESA_GL_VERSION_OVERRIDE=3.2 com.prusa3d.PrusaSlicer
Maybe that'll work on your systems?
I can't pretend to understand how this works, I found this method after a bunch of googling.
This post was modified 1 year temu by Sembazuru
See my (limited) designs on:
Opublikowany : 10/06/2025 10:57 pm
1 ludzie polubili
Reini
(@reini-2)
Unfortunately the given argument did not work for me... Any idea what kind of debug information to look for? I could not make sense out of the following debug info:
flatpak run com.prusa3d.PrusaSlicer --opengl-compatibility
Message: 17:52:13: Starting PrusaSlicer flatpak with entrypoint script
Gtk-Message: 17:52:14.095: Failed to load module "canberra-gtk-module"
Gtk-Message: 17:52:14.095: Failed to load module "pk-gtk-module"
[pr@wsccuw01 ~]$ Gtk-Message: 17:52:14.273: Failed to load module "canberra-gtk-module"
Gtk-Message: 17:52:14.273: Failed to load module "pk-gtk-module"
Gtk-Message: 17:52:14.276: Failed to load module "canberra-gtk-module"
Gtk-Message: 17:52:14.278: Failed to load module "pk-gtk-module"
[2025-06-11 17:52:16.602061] [0x00007fee860a7e40] [error]   UserAccount: Failed to read token - no datafile found.
[2025-06-11 17:52:16.701672] [0x00007fee4ffff6c0] [error]   Not primary owner of DBus name - probably another PrusaSlicer instance is running.
[2025-06-11 17:52:16.701696] [0x00007fee4ffff6c0] [error]   Dbus Messages listening terminating.
17:52:29: Debug: window wxTreeCtrl@0x55b1d3930090 ("treeCtrl") lost focus even though it didn't have it
This post was modified 12 months temu 2 times by Reini
Opublikowany : 11/06/2025 9:03 pm
Rob Welch
(@rob-welch)
Yes, that's exactly what my problem was.  I installed an older version to get around what I had assumed was an OpenGL issue.  It worked, and oddly enough, all the new features showed up too.  I guess I've got a hodgepodge of software chunks on this PC now.  Which means at some point, something will break and I'll have to spend a few days either archiving data files and starting over, or hand-picking the bad parts of different applications out.
I went with 2.8.0.
Opublikowany : 12/06/2025 2:10 pm
