Prusaslicer 2.9.1 give print times 8 times longer !!
robertpeschi
(@robertpeschi)
Hello,
I recently changed PC and reinstalled latest version of Prusa slicer 2.9.1.
If I slice again older .stl models, print times are now 4 to 5 times slower !
How could I fall back on a version with reasonable print times ?
Any one a clue ?
Thanks,
Robert, from Belgium
Opublikowany : 30/04/2025 3:11 pm
If the layer height and fill density are the same (and you have not changed other settings) then the print times should be similar - so check layers, perimeters and fill.
Opublikowany : 30/04/2025 3:51 pm
robertpeschi
(@robertpeschi)
RE: Prusaslicer 2.9.1 give print times 8 times longer !!
Thanks for the quick response !
I've checked settings and found that by default my PrusaSlicer was using 0.10mm DETAIL.
Changing it to 0.20mm SPEED made print time 4 time shorter !
Cheers
Opublikowany : 30/04/2025 9:37 pm
1 ludzie polubili
