prusaslicer 2.9.0 alpha1 - how to use scarf seam
Hi Dears,
Are you using the new feature ?
Do you know what is the benefits and interests of the new parameters :
- scarf joint placement
- scarf joint only on smooth
- scarf start height
- scarf joint around entire perimeter
- scarf joint length
- max scarf joint segment
- scarf joint on inner perimeters
- external perimeter first
and the possible influence of arachne generation
So far I have made a test on my MK3S with prusament PETG and standard prusa .2 quality profile for a simple cylinder with aligned seams, active scarf everywhere and keelping the other parameters defaults
The standard seam is now replaced by 2 smaller seams
Thanks for your help
RE: prusaslicer 2.9.0 alpha1 - how to use scarf seam
If you want to read about the supposed benefits then theres the original post requesting the devs implement it on the prusa githubn at https://github.com/prusa3d/PrusaSlicer/issues/11621
Its the next 'big thing' and as other slicers have it then Prusa seems to also have to have it to 'keep up'.
I did some tests with it in pla on my Neptune 3 Max when the alpha was released and personally I wont be using it. My printers settings are pretty well dialled in and the seam on my MK3 is minimal in the first place and my Neptune 3 has slightly more noticeable seams (but still not as bad as many I've seen pictured). That's why I decided to test it on the Max.
It made minimal difference to me except as you point out I now have 2 seams instead on 1. I tried various distances etc (not tried the whole perimeter) on various cylinders and also a dome shape. And like you I tried both Arachne and Classic perimeters. As I was using white filament which is difficult to photograph I didn't bother with pics, my main method was using touch on the seam. You can much more easily feel the effects than see them (at least with a properly tuned printer anyway).
I'm sure for some printers who's owners haven't got them dialled in nicely that it might make a difference but to me its not made any positive difference.
The Seam Gap Distance setting on the other hand I found to be more useful. That allowed me to tune the seam better and I did notice a small improvement when I dropped it 5% making the perimeter end closer to the start. My max can have a slight seam gap , especially at higher speeds. By moving it closer I have reduced that quite nicely. Making it negative (-5%)resulted in a slightly larger bump on the seam as expected as the end and start overlap at that point. Which is why I settled on +5%.
Version 2.9.0 alpha1 is the first time I have ever loaded a pre-release slicer version. I have been eagerly waiting for scarf seams to remove the dark seam holes that show up on light beige filament.
I set the seam position to random and use the default settings for everything else. The difference is amazing.
Still got my printed test parts. Although as mentioned in white so difficult to photograph.
Of the following 2 cylinders can you tell which is the scarf seam ? One is 2.9a with no scarf seam and the other is with a 10mm spacing scarf seam. The small black marks on the tops indicate where the seams are.
Another experiment on my side regarding seams on a light flying wing with 2 perimeters and .15 layer on prusament PLA and default profile on MK3S:
Without scarf, good print but obviously a small seam
With scarf, no seam but the vertical side is not vertical anymore with big deformation around the cylinder
I am still trying to understand the new parameters for the seam scarf !
