PrusaSlicer 2.6.0-alpha2 - No pad on branches
Mark de Ruijter
(@mark-de-ruijter)
You can see the pad is there on the classic supports, but its missing on the new branching settings. All other settings are the same. That as designed or not?
Opublikowany : 02/02/2023 1:33 pm
RE: PrusaSlicer 2.6.0-alpha2 - No pad on branches
This is a user to user forum.  If you have a question for the developers then you need to post on the appropriate github project.  For Prusa Slicer that is located here https://github.com/prusa3d/PrusaSlicer/issues
Opublikowany : 02/02/2023 1:35 pm
I don't understand the photos. Both look like tree supports, and not even like Prusaslicer. Can you upload the saved and compressed 3mf file?
Opublikowany : 02/02/2023 5:24 pm
Mark de Ruijter
(@mark-de-ruijter)
Sure, they are both zoomed in pictures of the model in PrusaSlicer. Yes, the supports are there, but no, in the branching version, there is no pad on the baseplate.
NoPad
I've included the file.
Opublikowany : 02/02/2023 6:03 pm
As I thought its a SLA profile @Fuchsr.  Didn't realise they had allowed the organic supports in the sla profiles too.  I suspect you will have to ask on github if the operation with no bottom layer is intentional as originally advised.  Given that most of the options are greyed out when branching is selected it could be either.
Opublikowany : 02/02/2023 8:43 pm
Ah, I see. As I don't want a chem lab in my home I never looked at the SLA side of PrusaSlicer 🙂
Opublikowany : 02/02/2023 8:52 pm
