Prusaslicer 2.3.0-rc3: support enforcer does not totally create supports
davidhajjar
(@davidhajjar)
Hello. I have a problem with a support enforcer. It does not totally fill the space with supports. Check the images:
It's a Minceraft Creeper. I want the eyes and mouth to be filled with supports, but 1 of the eyes has not supports generated. I've tried to move the enforcer, and to change its size. Sometimes even the other eyer has not supports, or has only partial support columns. That never happened before to me.
Note: today I have upgraded Prusaslicer from 2.2.0 to 2.3.0-rc3. Maybe it is an unreported bug?
Thank you.
Posted : 10/01/2021 10:26 pm
davidhajjar
(@davidhajjar)
RE: Prusaslicer 2.3.0-rc3: support enforcer does not totally create supports
Hello.
After many tries, moving and moving again the support enforcer, I've succeeded, and both eyes of the figure have supports!!
Why this happens? Thank you.
Posted : 10/01/2021 10:39 pm
Without having the saved project file where you are experiencing the problem (File>Save Project as) to output a 3mf we cant really tell you.
With a project file we can load it and slice with Exactly the same settings you are using as it saves the model and all modifiers etc.  We can then check any of the thousands of settings, the positioning of items, the model itself and possibly get an idea.
If you do want to attach your project file then be aware that the forum is very restricted on the file types allowed.  3mf or stl etc are not allowed.  You need to zip it up into an archive (.zip) file (or rename the 3mf as a zip file) to attach it to a post on the forum.
Posted : 12/01/2021 10:12 am
