PrusaSlicer 2.3.0 - Final release
Strona 1 / 3
Same Old Shane
(@same-old-shane)
Member Admin
Summary
This a final release of PrusaSlicer 2.3.0, introducing paint-on supports (video), ironing (video), monotonic infill, seam painting, adaptive and support cubic infill, print time per feature analysis, standalone G-code viewer application, better auto-arrange with a customizable gap and rotation, search function for the settings, reworked "Avoid crossing perimeters" function, physical printers (network settings), many new 3rd party printer profiles and much, much more.
The final release follows releases 2.3.0-alpha12.3.0-alpha22.3.0-alpha32.3.0-alpha42.3.0-beta12.3.0-beta22.3.0-beta32.3.0-rc12.3.0-rc2 and 2.3.0-rc3. This release fixes bugs found in the last release candidate. For all the new features in the 2.3.0 series, please read the change logs of all the alphas, betas and release candidates.
Unlike the alphas and the betas, the release build saves its profiles into PrusaSlicer directory, which is the same directory where the previous releases of PrusaSlicer (and the rcs) keep their profiles. If you were testing the PrusaSlicer 2.3.0 alphas or betas, your profiles from them would have to be manually imported into PrusaSlicer 2.3.0-rc3 by exporting and importing the Config Bundle.
Bugs fixed with respect to PrusaSlicer 2.3.0-rc3
  • Linux specific: Fixed new linker dependencies - glib and GTK libraries. (#5722#5739#5717, thanks @combolek)
  • Linux specific: Fixed "Single instance" feature for AppImage. (#5733)
  • Linux specific: Fixed a regression issue where a change in parameter was not accepted when switching between parameter pages. (#5720)
  • Fixed a crash when slicing an object producing no layers with Elephant Foot Compensation enabled. (5a1a410)
Supported printers:
  • Original Prusa i3 MK3S+ MMU2S
  • Original Prusa i3 MK3S MMU2S
  • Original Prusa i3 MK3 MMU2
  • Original Prusa i3 MK2.5S MMU2S
  • Original Prusa i3 MK2.5 MMU2
  • Original Prusa i3 MK2/S MMU1
  • Original Prusa SL1
  • Original Prusa MINI+
Download link:
prusa3d.com/prusaslicer
Please report any bug here:
github.com/prusa3d/PrusaSlicer/issues
We look forward to your feedback!
This topic was modified 4 years temu 4 times by Jakub Dolezal
Shane (AKA FromPrusa)
Opublikowany : 11/01/2021 6:45 pm
prusanewuser
(@prusanewuser)
RE: PrusaSlicer 2.3.0 Final Release.
Is there any improvement in ironing and gap filling between perimeters since rc3?
Opublikowany : 11/01/2021 8:10 pm
muddymaker
(@muddymaker)
Wrong download link?
Opublikowany : 11/01/2021 9:19 pm
muddymaker
(@muddymaker)
https://github.com/prusa3d/PrusaSlicer/releases
Opublikowany : 11/01/2021 9:30 pm
TheWarDoctor
(@thewardoctor)
While the download from Github appears to be working fine, the download from the official site (at least for macOS) is not:
https://www.prusa3d.com/drivers/
Attempting to download the complete ~600MB package gets no further than about 25MB before it stops. Investigation suggests I am receiving a HTTPS stream INTERNAL_ERROR code during the download. Any suggestions on the cause/when we can expect a fix?
Opublikowany : 11/01/2021 9:55 pm
TheWarDoctor
(@thewardoctor)
Posted by: @thewardoctor
And whatever the issue was has now been fixed 🙂
Opublikowany : 12/01/2021 1:54 am
It worked for me.  I wonder if it was a local thing.  Great update!
Opublikowany : 12/01/2021 11:23 am
NVGG Creations
(@nvgg-creations)
Spash screen says beta one for me.  I downloaded using the new installer from the Prusa software page.  Works fine when installing from github.  Can I now delete my Prusa3d folder that has the wrong version in it?
This post was modified 4 years temu by NVGG Creations
Opublikowany : 12/01/2021 1:40 pm
Dan Rogers
(@dan-rogers)
How do you install it?  I ran the old 2.2 slicer and under Help menu found "software releases"  That took me to github where I downloaded the topmost ZIP file.  Looking inside of it there don't seem to be any installers.  And there are no READ me.  And on the github article page, it is the same as this announce page - with no install instructions.
Beuller?  Beuller?  Did someone take a day off?
Opublikowany : 12/01/2021 4:23 pm
Lichtjaeger
(@lichtjaeger)
Posted by: @dan-rogers
The installers are here.
Opublikowany : 12/01/2021 4:26 pm
Dan Rogers polubić
Dan Rogers
(@dan-rogers)
@lichtjaeger
"Can't download - network issue" 🙁
Opublikowany : 12/01/2021 4:28 pm
adesir
(@adesir)
Download from here:
https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.3.0
Mes modeles publics
Opublikowany : 12/01/2021 5:05 pm
Same Old Shane
(@same-old-shane)
Member Admin
@muddymaker
Sorry guys, the link is corrected now.
Opublikowany : 13/01/2021 4:45 pm
Chris C
(@chris-c)
I am running into the error opening the "New version 2.3.0" it is telling me I need a new opengl32.dll......anyone know where I can spend time looking for a fix?  this is on my main laptop where i do all my 3D work......and yes I tried the --sw_renderer switch and it does not work...I guess they forgot to put in this version.
Opublikowany : 15/01/2021 4:34 am
lembo
(@lembo)
I had previously installed the last RC version and had set up a Creality CR-10 V2 under Printer Settings. When I installed the final release, that was still there under User Settings and Physical Printers, but when I try to add another Creality printer under Add/Remove Printers, I no longer see any predefined options other than for the Ender 3. What happened to all of the other models that had been available under the RC version?
Opublikowany : 15/01/2021 3:09 pm
Chris C
(@chris-c)
I figured it out.
Opublikowany : 15/01/2021 6:11 pm
Andre6553
(@andre6553)
Hi I have a Ender 3 Pro and have a problem with the new release.
When i set my print temp in the slicer and generate the g code it always generate g code 5 deg C below of what i set in slicer.
Here is my start g code
; generated by PrusaSlicer 2.3.0+win64 on 2021-01-15 at 15:55:06 UTC
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.35mm
; first layer extrusion width = 0.42mm
M73 P0 R22
M73 Q0 S22
M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X10.00 Y10.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
M190 S80 ; set bed temperature and wait for it to be reached
M104 S224 ; set temperature
;TYPE:Custom
G28 ; home all axes
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
G92 E0 ; Reset Extruder
M73 P1 R22
M73 Q1 S22
G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
G92 E0
G92 E0
M109 S224 ; set temperature and wait for it to be reached
G21 ; set units to millimeters
M82 ; use absolute distances for extrusion
G92 E0
; Filament gcode
;LAYER_CHANGE"
Opublikowany : 15/01/2021 6:18 pm
Andre6553
(@andre6553)
I have done a complete new profile setup and it seems like the problem is gone now .
Opublikowany : 15/01/2021 7:25 pm
Snag3d
(@snag3d)
there is a moded version with "dribbling mode" prusa should look into this and implement it for those who use mmu2 its really heloed me ive done prints with 800+ changes and 0 interventions, even with cheap pla, must have feature imo
Opublikowany : 16/01/2021 11:04 am
Hi Shane,
Could you share the information that you are talking about so that users can make changes instead of waiting for Prusa to make them?
Opublikowany : 16/01/2021 11:25 am
Strona 1 / 3
