PrusaSlicer 2.2.0-alpha2
Page 2 / 2
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
RE: PrusaSlicer 2.2.0-alpha2
@peter-h16
We released our official builds of PrusaSlicer 2.2.0-alpha4 for Raspberry PI 4 yesterday.
Posted : 10/02/2020 7:31 pm
tj
 tj
(@tj-2)
Posted by: @bubnikv
@torbjorn-j3
The elephant foot compensation for multi-material prints shall shrink just the outer contour of the cummulative object, it shall not adjust each sub-component independently. I know the older PrusaSlicer versions did it wrong, but the current PrusaSlicer 2.2.0-alpha2 and now alpha4 do it right.
Ok, good.
A good test case is one of the objects from the universal auto rewind spool holder (found it on thingiverse) and the object "NutCurved"
it got two different colors on first layer and if you slice it with version 2.1.0 of prusa slicer with elephant foot compensation turned on (0.2 for example) you end up with a large gap between the two colors.
Posted : 10/02/2020 8:04 pm
vintagepc
(@vintagepc)
woot, will DL and install tonight.
Posted : 10/02/2020 8:57 pm
Clemens M.
(@clemens-m)
@bubnikv
Where can I find that download?
Best regards, Clemens Mödlin
Posted : 12/02/2020 8:52 am
As always new releases can be found here https://github.com/prusa3d/PrusaSlicer/releases . Scroll down past the description of the release and you will see the available downloads.
Posted : 12/02/2020 10:11 am
Clemens M.
(@clemens-m)
@neophyl
Thanks a lot - I was already there, I forgot that I had to look for ... ARM ...
I will try it tonight
Best regards,
Clemens Mödlin
Posted : 12/02/2020 11:41 am
Clemens M.
(@clemens-m)
Works great - fast enough for slicing. Great step forward regarding my plan engineering and printing parts only using a Raspberry Pi 4 4GB. The missing link is at the moment ONSHAPE. There are still problems when working in ONSHAPE in sectional view.
Best regards,
Clemens Mödlin
Posted : 13/02/2020 3:43 pm
Page 2 / 2
