Prusament PETG preset disappears when selecting Original Prusa i3 MK3S 0.6 printer
Version 2.3.0-rc3+win64
I want to try out my 0.6 mm nozzle with PETG, and I noticed that I can't select Prusament PETG once I select the 0.6 mm nozzle printer. I can only select it for the 0.25 mm and 0.4 mm printers.
Is there a way to fix this?
RE: Prusament PETG preset disappears when selecting Original Prusa i3 MK3S 0.6 printer
That's odd...
It seems to work for me.
Win10, Intel i7 processor, Prusa slicer 2.3.0 RC3
@joantabb
Hi Joan,
That's good to know. I ran the wizard again and now everything looks correct.
Thanks,
Bill
Cheers Fabnavigator.
hopefully this has sorted it for you.
Quite funny as I seem to have the same problem. Changing from MK3S to MMU2S in the slicer does not let me chose most of my own presets but only one or two... I have not been able to figure out the problem...
Cheers
Chris
If I recall correctly a lot of the filaments are designed to Not be compatible with the Mmu profiles, so as soon as you select that option the filaments disappear from the list. This is by Prusa design.
