Prusa Slicer rendering issues
I'm trying to print a section of Honeycomb Storage Wall. I generated it in OpenSCAD and exported to STL. I pulled it into PrusaSlicer 2.9.0, and attempted to slice it, but it misinterpreted where the walls were.
My thought was, "ok, I can fix this." I pulled it into Blender and told Blender to merge nearby vertexes, then exported it to a new STL file. Yea, no, that didn't help.
Can anyone tell me what I'm doing wrong? Is there an easy way to fix this within the Slicer?
RE: Prusa Slicer rendering issues
use the
Fix by windows repair algorithm
Option in Prusa Slicer
Files > Save Project as
Without seeing your stl we cant say. I can say that openscad can cause lots of slicing problems. There have been numerous instances where it doesn't generate manifold models. When you took it into Blender did you run the 3dprint tool on it to see what it detects as errors ? Just merging vertices doesn't always help. Depends on exactly what is wrong.
If you want to post your model then don't forget to zip it up or the forum wont accept it.
Thanks. Here's the file. I would have posted it the first time, but didn't know about the zip restriction.
@JoanTabb, Are you talking about the one that saves it to an obj file? Yes, that one created an obj file with the same flaws.
@Neophyl, I tracked down the 3d print tools. Now I have to climb the learning curve. Thank you!
@neophyl has a point, OpenSCAD has a distribution problem. Many repositories still offer the 2019 version that has several issues for 3D printing. The latest stable version which is much better for printing use is 2021.01, make sure you are using this version. Development continues, slowly. If you wish to experiment, the current development snapshot was issued three days ago.
Over 300 open edges, slicer puts a warning triangle next to the listing - check your OpenSCAD version. If you are using 2021.01 post the script here and we'll take a closer look.
no, I mean the option where you right click on the model in the 3D editor view, which opens up a large menu of options in the middle of the screen, and you choose the
which then tries to fix any issues within the model
HSW_max fixed
Regards Joan
I'm currently using OpenSCAD 2023.06.26. The script I'm using is one of many off of Printables for making custom sized honeycomb storage walls. It makes all of the edges independently, then abuts them, and OpenSCAD is notorious for being poor at figuring out faces that are just barely not overlapping. @Diem, thank you for the offer, but I think I'm just going to look for other implementations or write one from scratch, see where that gets me.
@JoanTabb, My copy of PrusaSlicer (2.9.0) doesn't have that menu item. Scale to print volume is directly above Simplify Model, even using the Expert Mode interface. I'm running it on MacOS. Is this something that can be added?
I think Macos is the issue.
Netfabb might help, if you can run it.
Thank you, everyone, for talking this through with me. I've learned quite a bit regarding the limitations of various tools, and I did wind up finding a version of the Honeycomb Storage Wall OpenScad generator that produces reliable STLs. I just had to dig through the remixes until I found one that worked (marked v2.2).
That's not a stable release, you might like to download another from https://openscad.org/
Here's a quick and dirty version - modify module cell() to suit.
// Hex panel od=25; // Outside diameter - corner to corner id=22; // Intside diameter - corner to corner ht=10; comb(10,10); // for simplicity this is constrained to even y numbers module comb(xnumber,ynumber){ for (yc=[0:ynumber/2-1]){ translate([0,yc*(od+sin(30)*od),0]){ twostacked(xnumber); } } } module twostacked(number){ row(number); translate([cos(30)*od/2,od/2+sin(30)*od/2,0]){ row(number); } } module row(number){ for (xc=[0:number-1]){ translate([xc*cos(30)*od,0,0]){ rotate([0,0,30]){ cell(); } } } } module cell(){ difference(){ cylinder(d=od,h=ht,$fn=6); cylinder(d=id,h=ht,$fn=6); } }
Hth, cheerio,
