Prusa Slicer Removes Part of Design?
Hi all, I am trying to print this frame shown in the attached pictures. In the 1st image there is a support built into the design that is meant to be snapped off after printing is complete, however for some reason, when I slice the file this support just magically disappears.
Does anyone have any ideas / suggestions? I have included pictures as well as the STL file itself.
Best Answer by mrstoned:
The break-away builtin support might be too thin to print reliably with your current nozzle.
Try turning on detect thin walls
RE: Prusa Slicer Removes Part of Design?
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
The esteemed colleague is correct. In layman´s terms, the slicer shows in "sliced view" how parts will effectively be printed line by line - if the vertical layers are too thin to print with a certain nozzle then the slicer will (have to) disregard these layers as unprintable. It´s nicely visible if you try to print fine print letters e.g. on a plastic business card with a .4mm nozzle. The fineprint will usually become visible again if you switch the slicer to a finer nozzle, which will basically act as a proof of the root cause.
Aha, thanks! Just tried turning on detect thin walls and it works
I would just add that detect thin walls may result in other artifacts elsewhere in a model, so the safer approach is to model the breakaway support slightly thicker. May not be an issue here but may become a factor in future designs.
