Prusa Slicer Printer Status Only Showing for 1 Profile
FishyDEP
(@fishydep)
When in the plater tab on Prusa Slicer, the printer status (shown as green, red and blue dots for online, offline and printing) only shows for 1 of my profiles. In my case it's the Core One MMU3. For my Core One single profile and my custom profiles, I can't see printer status. See the attached pictures. What causes one profile to be the "default" and show the printer status while the others don't?
This topic was modified 2 months temu by FishyDEP
Opublikowany : 30/07/2025 12:33 am
Anže Zafran
(@anze-zafran)
RE: Prusa Slicer Printer Status Only Showing for 1 Profile
Were you able to solve this?
I have the same issue.
I also noticed that if:
  1. I go into PrusaSlicer
  2. then go into the PrusaConnect tab
  3. then click "Set as current" on the printer that does not show the colored status icons (in my case Prusa MK3.5S does not show colored icons, while MK4S does)
  4. the result is an error message from PrusaSlicer "Printer not found"
Which is very weird, since I can control the MK3.5S printer via PrusaConnect just fine.
On the other hand "setting the printer as current" works totally fine with the printer that has the colored icons up and running (MK4S)
Opublikowany : 12/08/2025 9:32 am
