Prusa Slicer merging my print-in-place bodies
UjinDesign
(@ujindesign)
Hi!
I've got a problem where Prusa Slicer merges bodies with small clearances / tolerances, meant to be print-in-place mechanisms, if the distance between bodies are <0.50 mm. I've previously managed to print multiple bodies being <0.15 mm apart (but I don't know how), and I've also previously printed https://www.printables.com/model/116911-clearance-tolerance-test without the bodies being merged (also don't know how).
Does anybody know if there is a setting / similar one can adjust to prevent Prusa Slicer from merging bodies into one when slicing? To clarify, I'm just doing a print-in-place hinge where the air gap between the male and the female is 0.15 mm. Printing in 0.15 (or 0.20) layer height with a 0.4n, stock settings.
Veröffentlicht : 29/07/2025 8:14 pm
RE: Prusa Slicer merging my print-in-place bodies
Not at pc at moment but search for slice gap closing radius.
Veröffentlicht : 29/07/2025 9:21 pm
