Prusa Slicer does not recognize the files ".ini" presents in "filament""print"and"printer" folders
Maurizio
(@maurizio)
Hello, I would like to be helped on the problem of recognition configurations. I install Prusa slicer, I import the configuration in Bundle and do not matter the filament settings, I copy them and paste them into the folder .... App/roaming/prusaslicer/filament but does not recognize them, I do not see them in the program, as you have to do to recognize all the files .ini present in the folders "filament" "print" and "printer" ???
Publié : 11/10/2022 5:36 pm
Membre
RE: Prusa Slicer does not recognize the files ".ini" presents in "filament""print"and"printer" folders
I have never used them.  Where did you get the ini files?
Publié : 11/10/2022 10:23 pm
Maurizio
(@maurizio)
I apologize for the late response, but I didn't notice your message. I'll answer out of duty in case it helps. The ".ini" file is created when you export a bundled configuration, from the "File" -> "Export" -> "Export configuration...." or "Export configuration in Bundle" or "Export configuration with physics printers", and are used to restore all the settings created in the event of a program crash. I apologize again for the delay.
Ce message a été modifié il y a 2 years par Maurizio
Publié : 25/10/2023 8:56 pm
