Prusa Slicer 2.7.4 ununderstandable slice result
PH.
 PH.
(@ph-3)
Utenti
I create a front for something and after Import Prusa slicer shows it up fine but after slicing it creates a closed box , see attached images and attached stl-zip
Radio_front_pre3-Body
Postato : 15/06/2024 3:43 pm
RE: Prusa Slicer 2.7.4 ununderstandable slice result
Your model is broken.  I loaded it into PS and it still has the orange triangle next to it in the list.  Hovering over it shows it repaired 12 edges but still has 5 open edges.  Using the right click and fix option  allows it to slice correctly.
Always look for the warning triangle, its there to alert you to issues.  Analysing your original stl in Blender it picks up 18 non manifold edges and 682 Zero Faces.  Generally zero faces don't cause a slicer issues but non manifold edges most certainly do.
I've attached a repaired version that should slice correctly.
Postato : 15/06/2024 4:17 pm
2 persone hanno apprezzato
PH.
 PH.
(@ph-3)
Utenti
@neophyl OMG i didn't spot it 🙁 sorry. Thanks for your answer and the file, i checked it here two and the result was fine.
but sometimes the repair feature seemed to make mistakes too, i remember several weeks ago the were errors to repair but
the repairment created a wrong part but slicing and printing without repairment worked.
thanks
Postato : 17/06/2024 6:47 am
