Prusa Slicer 2.3.1 config for CR-10 Max problem
I tried using the Prusa profile for the CR-10 Max and did a test print of the XYZ cube. The corners are bulge out(see pictures)
I was able to fix the issue using Cura by increasing jerk acceleration but I can't find the same setting in Prusa. I would prefer to use Prusa's slicer. I'm running a Micro Swiss hotend with a .6mm nozzle.
Thanks for the help
RE: Prusa Slicer 2.3.1 config for CR-10 Max problem
Jerk limits are located under Printer Settings>Machine Limits. Those are Advanced level settings so you must be in either Advanced or Expert mode to see them.
btw your pictures arent showing. Easiest way to add pictures here is to use the 'Add Media' button. The browse to your pictures and upload them. You can then add them to your post and control how they are shown with the options on the gallery controls.
Thank you
