Prusa Slicer 2.3.0 frozen when started after changing the default settings
[Resuelto] Prusa Slicer 2.3.0 frozen when started after changing the default settings
Laseru
(@laseru)
Hi guys,
Everything was working fine until I have decided to deselect auto supports and enable the supports.
After that the Slicer is hanging on starting, uninstall and reinstall does not help, it keeps using the old profile, how do I get to remove that setting so that I do a fresh install?
Prusa Slicer 2.3.0 on Win 10 latest
Best Answer by Laseru:
FYI,
I have uninsalled, then I have removed the files from my profile>appdata>prusa
I have removed some registry keys with prusa in the name, and after I have installed and it crashed once it started fine the second time.
So I think the trick to delete the files from the appdata folder in my profile solved it, not so sure about the registry keys.
Respondido : 04/02/2021 7:04 pm
Laseru
(@laseru)
RE: Prusa Slicer 2.3.0 frozen when started after changing the default settings
FYI,
Respondido : 04/02/2021 8:53 pm
