problem when launching Prusalicer v2.9.0 Flatpak the first time
I'm getting the following message when starting Prusaslicer the first time:
What do I have to do to resolve the problem?
What is the correct "CA bundle"?
I know this is more a Linux as a Slicer question, but maybe someone knows the answer.
TIA
Napsal : 21/12/2024 11:25 pm
1 lidem se líbí
RE: problem when launching Prusalicer v2.9.0 Flatpak the first time
If you don't use custom Certificate Authority ( and sinc you are asking you are probably not using it explicitly), then just select the check box on the left to remember your choice and click Yes.
Such certs are used in enterprise setups or if you have your own PKI for increased security/trust in the infra.
Napsal : 22/12/2024 3:16 pm
1 lidem se líbí
