Printer profile without defined MMU3 as a "start" profile for a printer profile using mmu3
stigcad
(@stigcad)
Hello from Vienna!
I have a quite good working printer profile for my mk4s using a user defined filament definition. Everything works fine for a printer profile without mmu3.
Now I have the idea to use this combination as a default profile (printer and filament) for a printer Profile with mmu3. The previous defined filament is the definition of the first extruder (for example)
When I use the "compare tool" with the transfer option, there is just one extruder defined in the "new" printer profile.
Is there a possibility to create the other 4 extruder in the new MMU3 printer profile based on the existing "single extruder" profile
I know, that it is necessary to do some adoptions to the  definitions of the single extruder.
On the other way I could change all the values (of the first extruder) manually - but that is a lot of work!
The MMU 3 works with certain filaments only - officially, but I think it should be possible to use user defined filaments with the MMU3 too - doing some adoptions to the profiles.
What do you think?
Thank you
Posted : 18/06/2025 9:40 am
MaryannWilliams
(@maryannwilliams)
RE: Printer profile without defined MMU3 as a "start" profile for a printer profile using mmu3
This is a perfectly reasonable idea, but it does have a few drawbacks as PrusaSlicer does not automatically map or convert all extruder parameters when switching from a single to a multi-material printer
X Trench Run
Posted : 19/06/2025 9:57 am
