Print Host upload 2.3.0-alpha1+
Dean
 Dean
(@dean-2)
I  just started to use the 2.3 Alpha. In the "Print Host upload" area it's now noting "Note: All parameters from this group are moved to the Physical Printer settings (see changelog)." And I'm unable to use my Octoprint connection. I'm not exactly sure what's being suggested. Isn't the 'Printer Settings" tab the "Physical Printer" settings?
Opublikowany : 22/10/2020 4:37 pm
towlerg
(@towlerg)
RE: Print Host upload 2.3.0-alpha1+
I think there are trying to differentiate between printer model and one particular printer.
Opublikowany : 22/10/2020 4:43 pm
At the moment it’s very confusing. Go to the plater and on the drop downs for selecting your printer click on the cog next to it. There will then be an option to add a physical printer. That pops up another window where you can enter the network stuff and also assign printers you already have defined against the new physical printer.
IT HAS TO BE THAT COG AND NOT the one on the printer settings area, even though you would expect them to be the same. Good luck.
Opublikowany : 22/10/2020 5:01 pm
1 ludzie polubili
Dean
 Dean
(@dean-2)
Thank you very much. I'm not sure I would have ever gotten there!
Opublikowany : 22/10/2020 5:05 pm
Only reason I knew was I saw this issue over on GitHub https://github.com/prusa3d/PrusaSlicer/issues/4891 where one of the devs explained what you had to do. I suspect it might be changed by the time of the full release.
Opublikowany : 22/10/2020 5:17 pm
JC
 JC
(@jc-2)
Octoprint is working fine, but when I try to add it to PS I get this error. I used my IP to my PI3. Any ideas? TIA! 😀
PS
NVM forgot to add the API.. DOH!! 🤪
This post was modified 6 years temu by JC
Opublikowany : 23/10/2020 8:07 pm
