Print area with G-Code variables
Pasubio
(@pasubio)
Hi all;
I need to obtain the max/min X and Y coordinates of the actual print area inside the G-code starting script.
I know that I can use the first_layer_print_min and first_layer_print_max placeholders, anyway I'm not able to understand how to extract min X/Y and max X/Y coordinates from this placeholders.
Moreover, do you suggest to use the pointed out placeholders or the print_bed_min and print_bed_max placeholders?
Thank you!
Postato : 21/06/2021 8:27 am
Pasubio
(@pasubio)
RE: Print area with G-Code variables
To explain better, in Simplify3D you can use [build_min_x], [build_max_x], [build_min_y], [build_max_y] placeholders, so I'm looking for the corresponding placeholders in PrusaSlicer.
Thank you!
Postato : 22/06/2021 7:18 am
I haven't played with these much myself, but the PrusaSlicer 2.3.0 announcementcontains some hints:
  • The G-code placeholder parser supports the following new keys: "print_bed_min", "print_bed_max", "print_bed_size", which are calculated as a bounding box of an existing "bed_shape" vector of points.
  • The G-code placeholder parser also newly supports the following new keys: "first_layer_print_convex_hull", "first_layer_print_min", "first_layer_print_max", "first_layer_print_size", defining convex hull of the first layer. Please note that the extrusions generated by the custom G-code are not accounted for.
Playing around with start gcode, the following statements seem to work as expected. With these lines in my start gcode:
; First layer print min: [first_layer_print_min_0],[first_layer_print_min_1]
; First layer print max: [first_layer_print_max_0],[first_layer_print_max_1]
; First layer print size: [first_layer_print_size_0],[first_layer_print_size_1]
I get this result when slicing a 30x40x50mm STL:
; First layer print min: 55.1281,30.2443
; First layer print max: 85.1281,70.2443
; First layer print size: 30,40
I'm just not certain about first_layer_print_min as the slicer says the part is positioned at 70.13,50.24. The max extent looks right based on that starting position and the print size is correct.
Postato : 22/06/2021 3:03 pm
Pasubio
(@pasubio)
Hi @bobstro,
thank you for your precious help.
I'm able to confirm the following placeholders translation:
  • Simplify 3D:  [build_min_x], [build_max_x], [build_min_y], [build_max_y]
  • PrusaSlicer:  [first_layer_print_min_0], [first_layer_print_max_0], [first_layer_print_min_1], [first_layer_print_max_1]
Important: the resulting coordinates contemplates also the skirt/brim/raft area if activated, not only the pure STL!
Questo post è stato modificato 4 years fa da Pasubio
Postato : 28/06/2021 1:33 pm
1 persone hanno apprezzato
showGoat
(@showgoat)
Utenti
Old thread, I know, but here's my version:
G29 X3 Y2 L[first_layer_print_min_0] F[first_layer_print_min_1] R[first_layer_print_max_0] B[first_layer_print_max_1]
Postato : 16/03/2024 5:14 pm
