poor surface quality above organic supports
Mia Silber
(@mia-silber)
Hi, I just tried versioin 2.9.3-beta1 and observe a very poor surface quality above organic supports.
What's your recommended setup to have e.g. the same amount as bottom layers and thickness above those supports - and best setup for PETG to remove supports easily?
What I currently find are loose filament threads or even fill patterns after removing the supports - so I guess I sometimes also ripped of the bottom layer when breaking off the supports.
Opublikowany : 06/09/2025 7:53 am
Snuffleupagus
(@snuffleupagus)
@mia-silber
beta's are for expert users not new users, get rid of the beta and continue your education with the last final version you have. Your only asking for trouble, you need to know many many things before using betas, alphas, or even Rc's. None of these are intended for the newbie community.
Regards
This post was modified 2 months temu by Snuffleupagus
Opublikowany : 07/09/2025 2:10 am
Pearson Marian
(@pearson-marian)
RE: poor surface quality above organic supports
Enable “Support Interface Only on Top” to avoid unnecessary support under overhangs. Consider tree supports if your slicer supports them—these minimize contact with the model. Use a 0.25 mm or 0.3 mm nozzle gap for PETG for easy removal.
Pearson Marian
Dinosaur Game
Opublikowany : 09/09/2025 2:04 am
