Perimeters before infill
Quinn Grudzinski
(@quinn-grudzinski-2)
Is there a way to force perimeters to print before infill in the newer PrusaSlicer releases 2.6+? I notice that if you have layers with minimal perimeters it will start printing infill first. This causes problems with the prints I'm making and have been stuck using older versions of prusa that don't have this feature.
Respondido : 29/01/2024 4:36 pm
What have you set in:
Print Settings > Infill > Advanced   ?
Respondido : 30/01/2024 12:01 am
Quinn Grudzinski
I don't have infill before perimeters selected. I am trying to print something that is mostly open infill. I would say most layers consist of 10% perimeters and 90% infill. I am printing multiple objects and can't use retractions. That means my infill becomes sparse in areas where the infill begins. However, I don't care as much about the quality of the perimeters which is why i prefer the layer starts there.
Esta publicación ha sido modificada el hace 2 years por Quinn Grudzinski
Respondido : 30/01/2024 2:02 pm
RE: Perimeters before infill
As I posted in your other post in the general sub forum can you please save your project file from PS (File>Save Project As) and then zip up the 3mf and attach it here to a reply.  Must be zipped or the forum wont attach the file.  With a 3mf we can see all your settings and it is much much easier to debug things as its a snapshot of your slice.
Your screen cap above for example has the infill before perimeters greyed out so not editable.  With the project we can see why that is for example.
Respondido : 30/01/2024 2:12 pm
