Performing a cut
CrazyBill
(@crazybill)
Performing a cut
Greetings all,
I've been using Slic3r for a while now and decided to try upgrading to Prusa 2.4.2,  When I make a cut, keeping both parts, it performs the cut but dumps both parts back on top of each other fused as one part again. The old Slic3r would place them separately on the build sheet.  Am I missing a setting somewhere?
Veröffentlicht : 30/08/2022 4:40 pm
RE: Performing a cut
I've never seen this. It always placed the two parts on the sheet.
Veröffentlicht : 30/08/2022 6:26 pm
towlerg
(@towlerg)
After cutting, look on the right panel, you will see (hopefully) two items. Initially both objects on the plater will be selected, select an item from the right hand panel and only the associated object on the plater will be highlighted.
Veröffentlicht : 31/08/2022 4:21 pm
CrazyBill
(@crazybill)
Thank you for the replies.
I went back today intending to get some screenshots and test it more and it seems to be working as it should now.  Only thing that I can think of is the computer was shutdown and rebooted.  When I experienced the issue it was immediately following installing the program so maybe a reboot was needed.
Anyway, Thanks
Veröffentlicht : 01/09/2022 1:07 am
