PE 2.4 - Wrong extruder/tool for temperature change (P0/P1, T0/T1, ecc.)
Pasubio
(@pasubio)
Hi all,
The scenario:
  • PE 2.4.0 for a RepRapFirmware printer.
  • Two physical extruders, the primary T0 and the secondary T1 (or P0/P1, if you want.)
  • Custom start-gcode: contain also T1 and M109 S[first_layer_temperature] T1
In the start-gcode I manually set T1 because I mainly print with the secondary extruder.
Everything is ok with the first layer, but in order to set the temperature for the "other layers" PE introduce the G10 P0 Sxxx command, while I would need the G10 P1 Sxxx command!
The result: no temperature change, the model is whole printed with the first layer temperature.
Any idea to fix this behavior?
It would be nice if PE would permit to manually set the P/T tool number for each extruder, but this is not possible!
Thank you!
Posted : 08/02/2022 1:17 pm
