RE: pause for filament change does not appear
Could be many things, from a setting somewhere to a corrupt configuration.
Save your project then take the resulting 3mf file and zip it up into an archive. Then attach the archive to a post here. It must be zipped up or the forum won’t t let you attach it. With the project file we can look at the settings and also look at the config if needed.
Here you have. I hope you guys could find something.
Thanks again
Also it could be if you have complete individual items enabled. With your project we can check.
@neophyl
It was that. I've just disable it and works again. Thanks a lot!!
@yanx
Glad that was it.
Are your posts in moderation due to being a new user ? I swear when I posted this morning your attached project wasn't showing up. Otherwise I could have checked and given a difinitive answer 🙂
@neophyl
I think it was because of that. This has been my first post
