Paint-On supports: how to select areas without being able to see them
qbl1
 qbl1
(@qbl1)
Mitglied
Hi, probably overseeing some feature here. If this is a duplicate of another thread, my apologies. Could not find anything, though I think somebody else must have bumped into this earlier.
I would like to place a nut during a pause while printing and then cover the nut. Therefore I modelled a "negative space" as placeholder for the nut. Also, I like the autogenerated supports for other parts of the object as it is more efficient than me drawing those lines myself or smart-fill complete areas (adding to the printtime).
So .. all I need to do, is to block supports for the cover part of the nut (marked with red in the attached pic) and press "auto generate supports". Yet I do not know how to select the areas for blocking in Prusa Slicer. AFAIK there is no "transparent view mode" or something I can use to see and select the area.
Up intill now, I was always able to reach such an area as the bolt hole was open on both sides, so with the correct angle I could see and select that area for support blockers. This time one side (the bottom in the pic) is closed so now I have no visual on the area (red arrow represents the visual being blocked by the closed bottom side), hence no idea how to block supports there.
Any help is appreciated...
Best Answer by Crab:
Maybe I'm missing something.. If you click on your model and choose PAINT ON SUPPORTS.. at the bottom of that dialog box is a slider titled: CLIPPING OF VIEW. So that lets you look at any angle.. let's say we look underneath. So flip the view. Then moving that slider, it causes layers to disappear, moving upwards from your view as you move the slider. This way you can get to any surface in your model. You just flip to a view where that surface will face you.. and you use that CLIPPING VIEW. You can then paint on BLOCK SUPPORTS, by using the right mouse button. Now you can still have the system generate supports by choosing EVERYWHERE in the Supports box on the right hand side, under the PrintSettings/Filament/Printer/Supports area. But it will block supports from where you painted them.
Did I understand the problem correctly?
Veröffentlicht : 24/09/2025 6:43 am
RE: Paint-On supports: how to select areas without being able to see them
One option is to use your 3D model Generator program to generate modifier blocks to surround the area where you don't want supports, then to save the modifier as a separate STL.
when the model is placed on the build plate in Prusa slicer, right click on the model, in 3D editor View, then choose 'Add Support Blocker > Part'
and import the Support blocker STL, that you created.
this should result in support blocking, exactly where you want.
Or,
In the Support Material Box, choose 'Generate Support Material'
and Unclick'AutoGenerateSupports'
then use the paint on supports option to add supports, only where you want them.
Veröffentlicht : 24/09/2025 10:10 am
qbl1
 qbl1
(@qbl1)
Mitglied
Hi Joan, thank you for your fast response.
I will try your suggestions tonight and get back if this solves the issue for me.
Veröffentlicht : 24/09/2025 11:45 am
qbl1
 qbl1
(@qbl1)
Mitglied
So if I understand correctly:
- option 1 basically boils down to export the bolt placeholders from Blender to an STL and import this in PrusaSlicer and mark them as a Support blocker.
- option 2 manually paint where I do want to have supports.
As my results for option 1 are a bit elaborate, let me start with option 2. I love the automatic painting option especially combined with the ability to block certain parts (by painting). It is quite efficient and seems to calculate the minimum amount of supports on the fly. Yet to be able to paint a part, one needs to be able to see that part. And this is where PrusaSlicer seems to miss the addtional functionality. If the visuals are blocked, I can not see the plane I like to paint (to add or block supports does not matter). The rendering of the object is always solid. Simplify model allows to view the wireframe, yet the object remains rendered solid. A translucent or wireframe only view would be beneficial in this this case. Did I miss this somewhere?
So I think I did what you suggested, yet I still get the supports inside the hexnut hole. Let me share the screenshots what I did and please advice where I did something wrong:
 STEP1: Import object to be printed in PrusaSlicer .. [OK]
STEP 2: load the hexnuts STL as a support blocker .. [OK]
STEP 3: check if if the hexnuts STL is placed correctly and is typed as "support blocker" .. [OK]
STEP 4:
- autopaint supports .. [OK]
- paint support block on items I can see .. [OK]
- "auto generated supports" is ticket off in the settings .. [OK]
STEP 5: slice the model and the supports should not show up .. [FAIL]
you can clearly see the green (supports) inside the hexnut area.
What did I misunderstood or do wrong?
Veröffentlicht : 24/09/2025 2:22 pm
Crab
 Crab
(@crab)
Veröffentlicht : 24/09/2025 7:30 pm
The problem with blockers if you are using the modifiers that you used to cut the pockets in the first place is the modifier needs to interpenetrate the surface you want to modify.  SO your blender modifiers need to be larger than the meshed cutting the pockets.
Auto painting is great sometimes but it can and will paint in areas you cant see and sometimes if you have geometry that is less than perfect such as an intersecting mesh area or similar you can't also paint a blocker on.  Imagine you have 'folded' mesh geometry or some other similar problem with your mesh and the auto paint paints facets than are folded.  It can do that as it paints based on angles.  If you try and manually paint that area though you can only paint on facets you can see.  Folded or intersecting faces etc cant be seen and so cant be manually painted.  In those instances an area modifier blocker though can catch those areas IF it completely covers the volume.
Btw to 'see' areas like inside those pockets you can use the Clipping function that is part of the various paint tools in Prusa Slicer.
Without the saved prusa slicer project file (3mf) to see how its all set up though anything is just general advice.  First thing is made your modifier meshes bigger or move them up 0.1mm so they intersect the surface you want to block.
Also one other thing to remember is that support always tries to work its way all the way down to the plater.  If its supporting something up high and you try to block a surface further down 'below' the supported area it will ignore the blocker and go down anyway.  Its a bit limited like that.
If you want to let us look at the project you can File>Save Project as and then ZIP up the 3mf PS produces.  That way we have a full picture and can give targeted advice.
Veröffentlicht : 24/09/2025 7:33 pm
qbl1
 qbl1
(@qbl1)
Mitglied
This exactly solves my problem very close to how I would like to have it solved. I never realized I any use case for the "clipping view".
Like I thought I probably missed some feature... or in this case missed the use case of a feature already there. Thanks!
Veröffentlicht : 25/09/2025 1:56 pm
qbl1
 qbl1
(@qbl1)
Mitglied
I solved it with the clipping view solution, but not leaving this opportunity go to waste, ... after some playing around indeed movin the shapes 0.01mm upward solved it as well.
Guess it is always good to have multiple tools/techniques at one's disposal to solve a problem.
Thank you as far a I am concerned this topic can be closed.
Veröffentlicht : 25/09/2025 2:02 pm
